Help Center/
Elastic Volume Service/
User Guide/
Managing EVS Recycle Bin/
Disabling the Recycle Bin
Updated on 2025-10-31 GMT+08:00
You can disable the recycle bin if you no longer need it.
You must empty the recycle bin before disabling it. To empty the recycle bin, you can:
- Recover the disks from the recycle bin by referring to Recovering Disks from the Recycle Bin.
- Permanently delete the disks from the recycle bin by referring to Permanently Deleting Disks from the Recycle Bin.
- Sign in to the EVS console.
- Click the Recycle Bin tab.
- In the upper right corner of the Recycle Bin tab page, click Disable Recycle Bin.
A dialog box is displayed.
- Click OK.
When message "Recycle bin is disabled" is displayed, the recycle bin is disabled successfully.
