Recording EVS Operations Using CTS
EVS supports the recording of EVS operations through CTS. You can query EVS traces and use them for historical operation audits and backtracks.
CTS has been enabled.
Key EVS Operations Recorded by CTS
| Operation | Resource | Trace |
| Create disk | evs | createVolume |
| Update disk | evs | updateVolume |
| Expand disk capacity | evs | extendVolume |
| Delete disk | evs | deleteVolume |
| Create disk tag | evs | createVolumeTag |
Viewing Traces
To view audit logs, see Querying Real-Time Traces.
