Help Center/ Elastic Volume Service/ User Guide/ Managing EVS Transfers
Updated on 2025-07-10 GMT+08:00
EVS transfer allows you to transfer disks from one account to another. After a transfer succeeds, the ownership of the disk belongs to the target account only.
Users can use disk transfer through APIs only. For more information, see EVS Transfer.
  • Monthly/yearly EVS disks cannot be transferred.
  • Frozen EVS disks cannot be transferred.
  • Encrypted EVS disks cannot be transferred.
  • EVS disks with backups and snapshots available cannot be transferred.
  • EVS disks associated with backup policies cannot be transferred.
  • DSS disks cannot be transferred.
  • EVS disks cannot be transferred across regions.
The following example shows you how to transfer an EVS disk from account A to account B. User A belongs to account A, and user B belongs to account B. User A creates the transfer. User B accepts the transfer using the transfer ID (transfer_id) and authentication key (auth_key). After the transfer has been accepted, the transfer is complete. Figure 1 shows the basic transfer process.
  • transfer_id specifies the disk transfer ID. Each EVS disk transfer has a transfer ID, and user B uses this ID to accept the disk transfer. The transfer ID expires after user B accepts the transfer.
  • auth_key specifies the identity authentication key of the disk transfer. Each EVS disk transfer has an authentication key, and user B uses this key for authentication when accepting the disk transfer.
Figure 1 EVS disk transfer process
  1. User A creates an EVS disk transfer. For details, see Creating an EVS Disk Transfer.
    After the transfer is successfully created, transfer_id and auth_key are returned.
  2. (Optional) User A views the disk transfer. For details, see Querying Details of an EVS Disk Transfer. If multiple disk transfers have been created, user A can query all disk transfers. For details, see Querying All EVS Disk Transfers or Querying Details of All EVS Disk Transfers.
  3. User A delivers the returned transfer_id and auth_key to user B.
  4. Check whether user B is going to accept the disk transfer.
    • If yes, go to 5.
    • If no, no further action is required.
      User A can delete the unaccepted disk transfer. For details, see Deleting an EVS Disk Transfer.
  5. User B accepts transfer_id and auth_key.
  6. User B accepts the transfer through transfer_id and auth_key. For details, see Accepting an EVS Disk Transfer.
