Updated on 2026-05-11 GMT+08:00
Modifying a Tag
You can change the value of a tag for an existing disk, but cannot change the key of a tag.
Tag Rules
A tag consists of a tag key and a tag value. Tag rules are described as follows: (Tag rules vary depending on regions. See the rules displayed on the console.)
First set of rules:
  • A tag key can contain a maximum of 36 characters. It can contain only letters, digits, special characters (. - _), and Unicode characters.
  • A tag value can contain a maximum of 43 characters. It can contain only letters, digits, special characters (. - _), and Unicode characters.
Second set of rules:
  • A tag key can contain a maximum of 36 characters. It cannot contain special characters (= * < > \\ , | /) or start or end with spaces.
  • A tag value can contain a maximum of 43 characters. It cannot contain special characters (= * < > \\ , | /) or start or end with spaces.
Third set of rules:
  • A tag key can contain a maximum of 128 characters. It cannot contain special characters (* < > \\ / , |), start with _sys_, or start or end with spaces.
  • A tag value can contain a maximum of 255 characters. It cannot contain special characters (* < > \\ , |) or start or end with spaces.
  • You can add a maximum of 20 tags for a single EVS disk.
  • Tag keys of the same EVS disk must be unique.
  1. Sign in to the EVS console.
  2. Click in the upper left corner and select a region.
  3. In the disk list, locate the desired disk and click the disk name.
    The disk details page is displayed.
  4. Click the Tags tab.
  5. Locate the target tag and click Edit in the Operation column.
    The Edit Tag page is displayed.
  6. Change the value of the tag and click OK.
    Return to the tag list. If the tag value is changed, the modification is complete.
Follow-Up Operations
After adding tags, you can search for disks by tag. For details, see Searching for Disks by Tag.
