Adding a Tag
You can add tags for an existing EVS disk. You can also add tags when creating a disk.
Tag Rules
A tag consists of a tag key and a tag value. Tag rules are described as follows: (Tag rules vary depending on regions. See the rules displayed on the console.)
- A tag key can contain a maximum of 36 characters. It can contain only letters, digits, special characters (. - _), and Unicode characters.
- A tag value can contain a maximum of 43 characters. It can contain only letters, digits, special characters (. - _), and Unicode characters.
- A tag key can contain a maximum of 36 characters. It cannot contain special characters (= * < > \\ , | /) or start or end with spaces.
- A tag value can contain a maximum of 43 characters. It cannot contain special characters (= * < > \\ , | /) or start or end with spaces.
- A tag key can contain a maximum of 128 characters. It cannot contain special characters (* < > \\ / , |), start with _sys_, or start or end with spaces.
- A tag value can contain a maximum of 255 characters. It cannot contain special characters (* < > \\ , |) or start or end with spaces.
- You can add a maximum of 20 tags for a single EVS disk.
- Tag keys of the same EVS disk must be unique.
- Sign in to the EVS console.
- Click
in the upper left corner and select a region. - In the disk list, locate the desired disk and click the disk name.
The disk details page is displayed.
- Click the Tags tab.
- Click Add Tag.
The Add Tag page is displayed.
- Enter a key and a value for a tag and click OK.
- Tag key: This parameter is mandatory.
- Tag value: This parameter is optional.
The Tags tab is displayed, and you can view the newly added tag.
Follow-Up Operations
After adding tags, you can search for disks by tag. For details, see Searching for Disks by Tag.
