Rolling Back Disk Data from a Snapshot
If data on an EVS disk is incorrect or damaged, you can roll back data from a snapshot to the source disk.
    After the data rollback, all the changes made after the snapshot was created will be lost.
- Snapshot data can only be rolled back to source EVS disks. Rollback to a different disk is not possible.
- If a snapshot is being created, it cannot be used to roll back disk data.
- A snapshot whose name starts with autobk_snapshot_vbs_, manualbk_snapshot_vbs_, autobk_snapshot_csbs_, or manualbk_snapshot_csbs_ is automatically generated during backup. Such a snapshot can only be viewed. It cannot be used to roll back the disk data.
- At least a snapshot has been created for the disk.
- You can only roll back disk data from a snapshot when the source disk status is Available (not attached to any server) or Rollback failed. If the source disk is attached, detach it first.
- Sign in to the EVS console.
- In the navigation pane on the left, choose Elastic Volume Service > Snapshots.
     The Snapshots page is displayed.
- In the snapshot list, locate the target snapshot and click Roll Back Disk in the Operation column.
- In the displayed dialog box, click Yes.
     The snapshot list is displayed. After the snapshot status changes from Rolling back to Available, the data rollback is successful.
Related Links
- If you expand the disk capacity after creating a snapshot for a data disk, the partition and file system created on the expanded capacity will be lost after you roll back data from this snapshot. You need to expand the capacity again by referring to Extending Disk Partitions and File Systems (Linux) and Extending Disk Partitions and File Systems (Windows).
- To check more snapshot FAQs, see Snapshot.
