Deleting an EVS Snapshot
When using EVS, you may encounter insufficient storage space, especially when the number of snapshots approaches the quota limit. This can directly affect the creation of new snapshots and other storage needs. If certain snapshots are no longer required or the snapshot count reaches the maximum allowed, you can delete unnecessary snapshots. It is recommended that you regularly check the snapshot usage and delete unnecessary snapshots to free up storage space and optimize resource management.
The snapshot status must be Available or Error.
| Item | Description |
| Legacy snapshots |
| Standard snapshots |
| General constraints |
- Sign in to the EVS console.
- Click
in the upper left corner and select a region. - In the navigation pane on the left, choose Elastic Volume Service > Snapshots.
The Snapshots page is displayed.
- In the snapshot list, locate the target snapshot and click Delete in the Operation column.
- In the displayed dialog box, confirm the information and click OK.
If the snapshot disappears from the snapshot list, the snapshot is deleted successfully.
Helpful Links
- For more snapshot FAQs, see Snapshot.
