Detaching an EVS Disk
| Disk Function | Server Status | Scenarios |
| System disk | Only offline detachment is supported. You can only detach a system disk when the server status is Stopped. |
| Data disk | Both online detachment and offline detachment are supported. You can detach a data disk when the server status is Stopped or Running. |
- For an attached system disk, the disk function is displayed as System disk, and the disk status is displayed as In-use in the disk list. After the system disk is detached, the disk function changes to Bootable disk, and the status changes to Available.
- Bootable disks are system disks that have been detached from servers. A bootable disk can be re-attached to a server to be used as a system disk or data disk depending on the disk function selected.
- For an attached data disk, the disk function is displayed as Data disk, and the disk status is displayed as In-use in the disk list. After the data disk is detached, the disk function remains unchanged, and the status changes to Available. For a shared disk, the status changes to Available only after it is detached from all its servers.
Billing
A detached EVS disk will not be automatically deleted, so it will still be billed, as described in Billing for EVS Disks. If you no longer need a disk, delete or unsubscribe from it in a timely manner.
- After a system disk is detached, some operations cannot be performed on the original server and the system disk. The unsupported operations are as follows:
- Server: starting the server, remote login, resetting the password, changing the server billing mode, changing server specifications, changing the OS, reinstalling the OS, creating images, creating backups, adding disks, changing the security group, and changing the VPC
- System disk: changing disk billing mode
- A shared data disk can be detached from ECSs in a batch.
- Before detaching an EVS disk from a running Windows server, ensure that no programs are reading data from or writing data to the disk. Otherwise, data will be lost.
- Before detaching an EVS disk from a running Linux server, you must log in to the server and run the umount command to cancel the association between the disk and the file system, and ensure that no programs are reading data from or writing data to the disk. Otherwise, you will not be able to detach the disk.
- You are advised to back up data. You can create snapshots or use CBR to create disk backups.
- Sign in to the ECS console.
- In the ECS list, locate the row that contains the target ECS, click More in the Operation column, and choose Stop.
When the ECS status changes to Stopped, the ECS has been stopped.
- Click the name of this ECS.
The ECS details page is displayed.
- Click the Disks tab to view the system disk attached to the ECS.
- Locate the row that contains the system disk and click Detach.
The Detach Disk dialog box is displayed.
- Click OK to detach the disk.
After the operation succeeds, the detached system disk is no longer displayed under the Disks tab.
- (Optional) Re-attach the bootable disk to another server. You can use it as a system disk or data disk depending on the disk function you select.
- Sign in to the EVS console.
- Choose a way to detach the disk by determining whether you want to check the server information first.
- If yes, perform the following procedure:
- If no, perform the following procedure:
- In the disk list, locate the row that contains the target disk and choose in the Operation column.
In the disk list, the disk status is Detaching, indicating that the disk is being detached from the server.
When the status changes to Available, the disk has been detached.
- In the disk list, click the name of the to-be-detached disk.
- Click the Servers tab to view the servers where the disk has been attached.
- Click
to select servers and click Detach Disk. Shared EVS disks support batch detachment, so you can select multiple servers at a time.
- Click
to select servers. Shared EVS disks support batch detachment, so you can select multiple servers at a time.
- Click Yes to detach the disk.
If a shared disk has been attached to multiple servers and you only detach it from some of the servers, the disk status will go back to In-use after the disk has been detached. The disk status changes to Available only after the disk has been detached from all the servers.
Helpful Links
- After disks are detached, you can attach them to other servers in the same AZ.
- To detach disks using the API, see Detaching an EVS Disk from an ECS.
- To check out more detachment FAQs, see Detachment.
