- What's New
- Getting Started
- User Guide
- Best Practices
- What Switches Can Connect to Enterprise Switches?
- Why Is the Layer 2 Connection in the Not Connected State Even After Its Configuration Is Complete?
- Can Enterprise Switches Enable Communications Between Different Clouds?
- Why Is Communication Between the Cloud and On-premises Servers Unavailable Even When the Layer 2 Connection Status Is Connected?
- More Documents
Help Center/
Enterprise Switch/
User Guide/
Cloud Eye Monitoring/
Storing Monitoring Data to OBS Buckets
This section describes how to configure OBS for enterprise switches to store their historical monitoring data.
Raw monitoring data of metrics is kept for only two days on Cloud Eye. For permanent data storage, enable Object Storage Service (OBS), and store raw monitoring data to OBS buckets.
- Click
in the upper left corner and select the desired region and project.
- In the upper left corner of the page, click
to open the service list and choose Management & Deployment > Cloud Eye.
- In the navigation pane on the left, choose Cloud Service Monitoring > Enterprise Switch.
- In the enterprise switch list, locate the row that contains the enterprise switch and click Configure Storage in the Operation column.
The Configure Storage page is displayed.
- On the Configure Storage page, configure parameters as prompted.
Parent topic: Cloud Eye Monitoring
