- What's New
- Getting Started
- User Guide
- Best Practices
- What Switches Can Connect to Enterprise Switches?
- Why Is the Layer 2 Connection in the Not Connected State Even After Its Configuration Is Complete?
- Can Enterprise Switches Enable Communications Between Different Clouds?
- Why Is Communication Between the Cloud and On-premises Servers Unavailable Even When the Layer 2 Connection Status Is Connected?
- More Documents
Creating a Layer 2 Connection
After an enterprise switch is created, you need to create a Layer 2 connection to enable the local Layer 2 connection subnet and the remote VXLAN switch to communicate at Layer 2.
Notes and Constraints
- Each Layer 2 connection connects a local and a remote Layer 2 connection subnet. Each enterprise switch supports a maximum of six Layer 2 connections.
- The Layer 2 connections of an enterprise switch can share a tunnel IP address, but their tunnel VNIs must be unique. A tunnel VNI is the identifier of a tunnel.
- If a Layer 2 connection connects a local Layer 2 connection subnet to an enterprise switch, the local Layer 2 connection subnet must have two IP addresses reserved as active and standby interface IP addresses. The two IP addresses cannot be used by any local resources and must be different from the IP addresses in the remote Layer 2 connection subnet.
- Go to the Enterprise Switch page.
Locate the enterprise switch that you want to create a Layer-2 connection.
- In the lower right part of the enterprise switch details page, click Create Connection.
The page for creating a Layer 2 connection is displayed.
- Configure the parameters as prompted. For details, see Table 1.
Table 1 Parameters for creating a Layer-2 connection Parameter
Example Value
Name of the enterprise switch. You do not need to set this parameter.
l2cg-01
VPC
VPC that is associated with the enterprise switch, that is, the VPC that the local tunnel subnet belongs to. You do not need to set this parameter.
vpc-01
Layer 2 Connection Subnet
Mandatory
Select the layer 2 connection subnet in the VPC. This Layer 2 connection subnet is used to communicate with the Layer 2 connection subnet in an on-premises data center at Layer 2.
- The local and remote Layer 2 connection subnets can overlap, but the IP addresses of the servers that need to communicate in the local and remote subnets must be different. Otherwise, the communication fails.
- A VPC subnet that has been used a Layer 2 connection cannot be used by any other Layer 2 connections or enterprise switches.
subnet-01
Interface IP Address
Mandatory
IP addresses in the VPC subnet that are connected to the enterprise switch, including active and standby interface IP addresses. The IP addresses can be automatically assigned or manually specified.
Automatically assign
Remote Access Information > Tunnel VNI
Mandatory
Network identifier of the VXLAN tunnel used by an on-premises data center to connect to an enterprise switch, which is used to uniquely identify the VXLAN. For the same VXLAN tunnel, the on-premises data center and the cloud must use the same tunnel VNI.
10001
Remote Access Information > Tunnel IP Address
Mandatory
IP address of the VXLAN tunnel used by the on-premises data center to connect to the enterprise switch.
Remote Access Information > Tunnel Port
Port number of the VXLAN tunnel used by the on-premises data center to connect to the enterprise switch. Port 4789 is used by default. You do not need to set this parameter.
4789
Name
Mandatory
Enter the name of the Layer 2 connection. The name:- Must contain 1 to 64 characters.
- Can contain letters, digits, underscores (_), hyphens (-), and periods (.).
l2conn-01
- Click Create.
This operation takes 20 to 60 seconds to complete. If the status is Not connected or Connected, the Layer 2 connection is created.
