Help Center/ Enterprise Switch/ User Guide/ Enterprise Switches/ Deleting an Enterprise Switch
Updated on 2025-10-14 GMT+08:00
You can delete an enterprise switch to release resources and reduce costs if it is no longer required.
Notes and Constraints
An enterprise switch with Layer 2 connections associated cannot be deleted. To delete such an enterprise switch, delete the Layer 2 connections first. For details, see Deleting a Layer 2 Connection.
  1. Go to the Enterprise Switch page.
    Locate the enterprise switch you want to delete.
  1. In the upper right corner of the enterprise switch details page, click Delete.
    A confirmation dialog box is displayed.
  2. Click OK.
    This operation takes 10 to 60 seconds to complete.
