- What's New
- Getting Started
- User Guide
- Best Practices
- What Switches Can Connect to Enterprise Switches?
- Why Is the Layer 2 Connection in the Not Connected State Even After Its Configuration Is Complete?
- Can Enterprise Switches Enable Communications Between Different Clouds?
- Why Is Communication Between the Cloud and On-premises Servers Unavailable Even When the Layer 2 Connection Status Is Connected?
- More Documents
Help Center/
Enterprise Switch/
User Guide/
Enterprise Switches/
Viewing Details of an Enterprise Switch
This section describes how to view basic information about an enterprise switch.
- Go to the Enterprise Switch page.
- Locate the enterprise switch and view its details.
Parent topic: Enterprise Switches
