Updated on 2024-08-02 GMT+08:00
Dashboard Management
You have logged in to ESM as an administrator.
  1. Choose Visualization > Dashboards Management from the main menu.
  2. Perform operations by referring to Table 1.
    Table 1 Dashboards management items
    Item
    Custom Logo
    Custom dashboard logos can be uploaded.
    This function is available only to users of regions where the professional edition is enabled.
    1. In the navigation pane, choose Dashboards Management > Custom Logo.
    2. Click Change.
    3. After selecting a file, click Upload.
      The logo image format can be JPG, JPEG, or PNG. The logo resolution cannot exceed 120 x 120 pixels, and the image cannot be larger than 50 KB. A transparent background is recommended.
    Subscription
    Dashboards can be authorized to sub-users of the tenant account.
    This function is available only when you have the te_admin and "sec_admin" roles.
    1. In the navigation pane, choose Dashboards Management > Subscription.
    2. Select a dashboard and choose Modify in the Operation column.
    3. Add a sub-user to the subscriber list.
      A maximum of 10 sub-users can be added.
    4. Click OK.
