Help Center/ Enterprise Router/ User Guide/ Routing Control/ AS_Path Lists/ Deleting an AS_Path Filter from an AS_Path List
Updated on 2026-07-14 GMT+08:00
This section describes how to delete an AS_Path filter.
Notes and Constraints
  • AS_Path filters change the path through which network traffic passes. If a route policy has already been associated with an enterprise router, evaluate the impact on services before deleting an AS_Path filter from an AS_Path list.
  • Each AS_Path list must contain at least one AS_Path filter. If you want to delete the last AS_Path filter from an AS_Path list, you can add an AS_Path filter and then delete the old filter.
  1. Go to the AS_Path Lists page.
  2. Click the name of the target AS_Path list.
    The AS_Path filters are displayed.
  3. Locate the row that contains the target AS_Path filter and click Delete in the Operation column.
    A confirmation dialog box is displayed.
  4. Confirm the information and click OK.
    Deleted AS_Path filters cannot be recovered.
