Help Center/ Enterprise Router/ User Guide/ Routing Control/ AS_Path Lists/ Adding an AS_Path Filter to an AS_Path List
Updated on 2024-08-19 GMT+08:00
This section describes how to add an AS_Path filter to an AS_Path list. Each AS_Path list can have multiple AS_Path filters.
Notes and Constraints
  • AS_Path filters change the path through which network traffic passes. If a route policy has already been associated with an enterprise router, evaluate the impact on services before adding an AS_Path filter to an AS_Path list.
  • Each filter in an AS_Path list must have its unique sequence number.
An AS_Path list is available. You can create one by referring to Creating an AS_Path List.
  1. Go to the AS_Path Lists page.
  2. Click the name of the target AS_Path list.
    The AS_Path filters are displayed.
  3. Click Add AS_Path Filter in the upper left corner of the filter list.
    The Add AS_Path Filter dialog box is displayed.
  4. Configure the parameters based on Table 1.
    Table 1 Parameters for adding an AS_Path filter
    Example Value
    Sequence Number
    Mandatory
    An AS_Path list consists of one or more AS_Path filters that are applied to filter routes based on their sequence numbers, in ascending order. A sequence number can be from 0 to 65535.
    10
    Action
    Mandatory
    Select Allow or Deny.
    • If a route matches an AS_Path filter with Action set to Allow, the route is allowed.
    • If the AS_Path filter has Action set to Deny, the route is denied.
    Allow
    Regular Expression
    A regular expression is a string that describes a characteristic and verifies whether another string conforms to this characteristic. An AS_Path filter defines an AS_Path regular expression to match AS_Path attributes of BGP routes for filtering BGP routes.
    For details, see AS_Path Regular Expressions.
    65+
  5. Click OK.
    In the AS_Path filter list, you can view the created AS_Path filter.
Follow-Up Operations
Deleting an AS_Path Filter from an AS_Path List: An AS_Path filter cannot be modified after being added. You can delete an AS_Path filter that you do not need and add another one.
