Updated on 2026-07-14 GMT+08:00
Deleting an AS_Path List
This section describes how to delete an AS_Path list.
Notes and Constraints
If the route policy that an AS_Path list to be deleted belongs to has been associated with an enterprise router, change the route policy to not use this AS_Path list by referring to Modifying a Policy Node in a Route Policy.
  1. Go to the AS_Path Lists page.
  2. Locate the row that contains the AS_Path list you want to delete and click Delete in the Operation column.
    A confirmation dialog box is displayed.
  3. Confirm the information and click OK.
    Deleted AS_Path lists cannot be recovered.
