- What's New
- Function Overview
- Billing
- Getting Started
User Guide
- Permissions Management
- Enterprise Routers
- Attachments
- Route Tables
- Associations
- Propagations
- Routes
Routing Control
Route Policies
- Route Policy Overview
- Creating a Route Policy
- Associating a Route Policy with an Enterprise Router
- Changing the Route Policy Associated with an Enterprise Router
- Disassociating a Route Policy from an Enterprise Router
- Modifying a Route Policy
- Viewing a Route Policy
- Deleting a Route Policy
- Adding a Policy Node to a Route Policy
- Modifying a Policy Node in a Route Policy
- Exporting Policy Nodes in a Route Policy
- Viewing a Policy Node in a Route Policy
- Deleting a Policy Node from a Route Policy
IP Prefix Lists
- IP Prefix List Overview
- Creating an IP Prefix List
- Modifying the Name of an IP Prefix List
- Viewing an IP Prefix List
- Deleting an IP Prefix List
- Adding a Prefix Rule to an IP Address Prefix List
- Modifying an IP Prefix Rule in an IP Prefix List
- Exporting Prefix Rules in an IP Prefix List
- Viewing a Prefix Rule in an IP Prefix List
- Deleting a Prefix Rule from an IP Prefix List
AS_Path Lists
- AS_Path List Overview
- Creating an AS_Path List
- Modifying the Name of an AS_Path List
- Viewing an AS_Path List
- Deleting an AS_Path List
- Adding an AS_Path Filter to an AS_Path List
- Exporting AS_Path Filters in an AS_Path List
- Viewing an AS_Path Filter in an AS_Path List
- Deleting an AS_Path Filter from an AS_Path List
Route Policies
- Sharing
- Flow Logs
- Monitoring and Auditing
- Tags
- Quotas
Best Practices
- Summary on Enterprise Router Best Practices
- Connecting VPCs Across Regions Using Enterprise Router and Central Network
- Using Enterprise Router to Isolate VPCs in the Same Region
- Using a Third-Party Firewall to Protect VPCs Connected by Enterprise Routers
- Enabling an On-Premises Data Center to Access Service VPCs Using an Enterprise Router and Transit VPC
- Setting Up a Hybrid Cloud Network Using Enterprise Router and Direct Connect Global DC Gateway
Setting Up a Hybrid Cloud Network Using Enterprise Router and a Pair of Direct Connect Connections (Global DC Gateway)
- Overview
- Network and Resource Planning
- Process of Setting Up a Hybrid Cloud Network Using Enterprise Router and a Pair of Direct Connect Connections (Global DC Gateway)
- Procedure for Setting Up a Hybrid Cloud Network Using Enterprise Router and a Pair of Direct Connect Connections (Global DC Gateway)
Setting Up a Hybrid Cloud Network Using Enterprise Router and a Pair of Active/Standby Direct Connect Connections (Global DC Gateway)
- Overview
- Process of Setting Up a Hybrid Cloud Network Using Enterprise Router and a Pair of Active/Standby Direct Connect Connections (Global DC Gateway)
- Procedure for Setting Up a Hybrid Cloud Network Using Enterprise Router and a Pair of Active/Standby Direct Connect Connections (Global DC Gateway)
- Setting Up a Hybrid Cloud Network Using Enterprise Router, VPN, and Direct Connect (Global DC Gateway)
- Setting Up a Hybrid Cloud Network Using Enterprise Router and Direct Connect (Virtual Gateway)
- Setting Up a Hybrid Cloud Network Using Enterprise Router and a Pair of Direct Connect Connections (Virtual Gateway)
- Setting Up a Hybrid Cloud Network Using Enterprise Router, VPN, and Direct Connect (Virtual Gateway)
- Allowing VPCs to Share an EIP to Access the Internet Using Enterprise Router and NAT Gateway
- Using Enterprise Router to Migrate the Network Set Up Through VPC Peering
- Using Enterprise Router to Migrate the Network Set Up Through Direct Connect (Global DC Gateway)
- Using Enterprise Router and Central Network to Migrate the Network Set Up Through a Cloud Connection
- API Reference
- FAQs
More Documents
- Getting Started
- Attachments
- Route Tables
- Associations
- Propagations
- Routes
- Sharing
- Flow Logs
- Monitoring
- Interconnecting with CTS
- Tags
- Quotas
- FAQ
- Change History
User Guide (Ankara Region)
- Getting Started
- Attachments
- Route Tables
- Associations
- Propagations
- Routes
- Sharing
- Flow Logs
- Monitoring
- Quotas
- FAQ
- Change History
- API Reference (Ankara Region)
This section describes how to create an IP prefix list.
Notes and Constraints
- An IP prefix list must have at least one prefix rule.
- Each prefix rule in an IP prefix list must have its unique sequence number and IP prefix.
- Go to the Prefix Lists page.
- Click Create Prefix List in the upper right corner of the page.
The Create Prefix List dialog box is displayed.
- Configure the parameters based on Table 1.
Table 1 Parameters for creating an IP prefix list Parameter
Example Value
Name
Mandatory
Enter a name for the IP prefix list. The name:- Can contain 1 to 64 characters.
- Can contain letters, digits, underscores (_), hyphens (-), and periods (.).
prefixFilter-ab
Optional
Enter the description of the IP prefix list in the text box.
Configuration
Mandatory
Choose Quick or Advanced.- Quick
Enter the IP prefix in the CIDR format. An IP prefix specifies the first bits of an IP address range that a route destination must match.
The following are parameters that you do not need to configure:- Sequence Number: Automatically generated. The sequence number increases by a multiple of 10, with that of the first rule set to 10. The subsequent numbers are 20, 30, and so on.
- Action: Allow by default
- Min. Netmask Length and Max. Netmask Length
- Advanced
- Sequence Number: An IP prefix list consists of one or more prefix rules that are applied to filter routes based on their sequence numbers, in ascending order. A sequence number can be from 0 to 65535. You are advised to set the sequence number of the first rule to 20.
- Action: Select Allow or Deny. If a route matches a prefix rule with Action set to Allow, the route is allowed. If the prefix rule has Action set to Deny, the route is denied.
- IP Prefix: Enter the IP prefix in the CIDR format. This parameter specifies the first bits of an IP address range that a route destination must match.
- Min. Netmask Length: It cannot be smaller than the netmask length of the IP prefix. For example, if the netmask length of the IP prefix is 16, the min. netmask length must be greater than or equal to 16 (for example, 18).
- Max. Netmask Length: It cannot be smaller than the min. netmask length. For example, if the min. netmask length is 18, the max. netmask length must be from 18 to 32 (for example, 20).
- Sequence Number: 10
- Action: Allow
- IP Prefix: 10.0.0.0/16
- Min. Netmask Length: 20
- Max. Netmask Length: 28
- Click OK.
You can view the created IP prefix list.
Follow-Up Operations
Creating a Route Policy: An IP prefix list takes effect through a route policy.
