Help Center/ Enterprise Router/ User Guide/ Routing Control/ Route Policies/ Deleting a Policy Node from a Route Policy
Updated on 2026-07-14 GMT+08:00
This section describes how to delete a node from a route policy.
Notes and Constraints
- Route policies change the path through which network traffic passes. If a route policy has already been associated with an enterprise router, evaluate the impact on services before deleting its nodes.
- Each route policy must contain at least one node. If you want to delete the last node from a route policy, you can add a node and then delete the last node.
- Go to the Route Policies page.
- Click the name of the target route policy.
The node list is displayed.
- In the node list, perform the following operations to delete a node:
- To delete a single node, locate the node you want to delete and click Delete in the Operation column.
A confirmation dialog box is displayed.
- To delete multiple nodes, select the nodes and click Delete in the upper left corner of the list.
- Confirm the information and click OK.
Deleted nodes cannot be recovered.
Parent topic: Route Policies
0
3
4
5
6
7
8
9
10
Very dissatisfiedVery satisfied
