- What's New
- Function Overview
- Billing
- Getting Started
User Guide
- Permissions Management
- Enterprise Routers
- Attachments
- Route Tables
- Associations
- Propagations
- Routes
Routing Control
Route Policies
- Route Policy Overview
- Creating a Route Policy
- Associating a Route Policy with an Enterprise Router
- Changing the Route Policy Associated with an Enterprise Router
- Disassociating a Route Policy from an Enterprise Router
- Modifying a Route Policy
- Viewing a Route Policy
- Deleting a Route Policy
- Adding a Policy Node to a Route Policy
- Modifying a Policy Node in a Route Policy
- Exporting Policy Nodes in a Route Policy
- Viewing a Policy Node in a Route Policy
- Deleting a Policy Node from a Route Policy
IP Prefix Lists
- IP Prefix List Overview
- Creating an IP Prefix List
- Modifying the Name of an IP Prefix List
- Viewing an IP Prefix List
- Deleting an IP Prefix List
- Adding a Prefix Rule to an IP Address Prefix List
- Modifying an IP Prefix Rule in an IP Prefix List
- Exporting Prefix Rules in an IP Prefix List
- Viewing a Prefix Rule in an IP Prefix List
- Deleting a Prefix Rule from an IP Prefix List
AS_Path Lists
- AS_Path List Overview
- Creating an AS_Path List
- Modifying the Name of an AS_Path List
- Viewing an AS_Path List
- Deleting an AS_Path List
- Adding an AS_Path Filter to an AS_Path List
- Exporting AS_Path Filters in an AS_Path List
- Viewing an AS_Path Filter in an AS_Path List
- Deleting an AS_Path Filter from an AS_Path List
Route Policies
- Sharing
- Flow Logs
- Monitoring and Auditing
- Tags
- Quotas
Best Practices
- Summary on Enterprise Router Best Practices
- Connecting VPCs Across Regions Using Enterprise Router and Central Network
- Using Enterprise Router to Isolate VPCs in the Same Region
- Using a Third-Party Firewall to Protect VPCs Connected by Enterprise Routers
- Enabling an On-Premises Data Center to Access Service VPCs Using an Enterprise Router and Transit VPC
- Setting Up a Hybrid Cloud Network Using Enterprise Router and Direct Connect Global DC Gateway
Setting Up a Hybrid Cloud Network Using Enterprise Router and a Pair of Direct Connect Connections (Global DC Gateway)
- Overview
- Network and Resource Planning
- Process of Setting Up a Hybrid Cloud Network Using Enterprise Router and a Pair of Direct Connect Connections (Global DC Gateway)
- Procedure for Setting Up a Hybrid Cloud Network Using Enterprise Router and a Pair of Direct Connect Connections (Global DC Gateway)
Setting Up a Hybrid Cloud Network Using Enterprise Router and a Pair of Active/Standby Direct Connect Connections (Global DC Gateway)
- Overview
- Process of Setting Up a Hybrid Cloud Network Using Enterprise Router and a Pair of Active/Standby Direct Connect Connections (Global DC Gateway)
- Procedure for Setting Up a Hybrid Cloud Network Using Enterprise Router and a Pair of Active/Standby Direct Connect Connections (Global DC Gateway)
- Setting Up a Hybrid Cloud Network Using Enterprise Router, VPN, and Direct Connect (Global DC Gateway)
- Setting Up a Hybrid Cloud Network Using Enterprise Router and Direct Connect (Virtual Gateway)
- Setting Up a Hybrid Cloud Network Using Enterprise Router and a Pair of Direct Connect Connections (Virtual Gateway)
- Setting Up a Hybrid Cloud Network Using Enterprise Router, VPN, and Direct Connect (Virtual Gateway)
- Allowing VPCs to Share an EIP to Access the Internet Using Enterprise Router and NAT Gateway
- Using Enterprise Router to Migrate the Network Set Up Through VPC Peering
- Using Enterprise Router to Migrate the Network Set Up Through Direct Connect (Global DC Gateway)
- Using Enterprise Router and Central Network to Migrate the Network Set Up Through a Cloud Connection
- API Reference
- FAQs
More Documents
- Getting Started
- Attachments
- Route Tables
- Associations
- Propagations
- Routes
- Sharing
- Flow Logs
- Monitoring
- Interconnecting with CTS
- Tags
- Quotas
- FAQ
- Change History
User Guide (Ankara Region)
- Getting Started
- Attachments
- Route Tables
- Associations
- Propagations
- Routes
- Sharing
- Flow Logs
- Monitoring
- Quotas
- FAQ
- Change History
- API Reference (Ankara Region)
This section describes how to modify a node in a route policy.
Notes and Constraints
- Route policies change the path through which network traffic passes. If a route policy has already been associated with an enterprise router, evaluate the impact on services before modifying its nodes.
- Changing a route policy will also change the associated routes. To reduce the impact on network performance, a route policy can only be changed once within 40 seconds.
- Go to the Route Policies page.
- Click the name of the target route policy.
The node list is displayed.
- Locate the row that contains the node you want to modify and click Modify in the Operation column.
The page for modifying a node is displayed.
- Configure the parameters based on Table 1.
Table 1 Parameters for modifying a node Parameter
Example Value
Node Number
Cannot be modified.
Action
Cannot be modified.
Match Condition
Mandatory
Select match conditions. You can select a route type, prefix list, or AS_Path list.- Route type
- Static: Manually configured routes
Custom routes and propagated routes of VPC attachments in enterprise router route tables are static routes.
- BGP: Routes learned through BGP
Direct Connect global DC gateways communicate with enterprise routers using BGP so the routes of global DC gateway attachments propagated to enterprise router route tables are BGP routes.
Also, the routes of peering connection attachments and VPN gateway attachments propagated to enterprise router route tables are BGP routes.
- An IP prefix list contains prefix rules for route filtering. You can define IP prefixes and netmasks in prefix rules to match the destination addresses or next hops of routes. For more information, see IP Prefix List Overview.
- An AS_Path list is a collection of filters that are used to filter BGP routes based on AS_Path attributes contained in BGP routes. AS_Path attributes record the number of each AS that BGP routes pass through from the source to the destination in distance-vector order. For more information, see AS_Path List Overview.
- Route type: BGP
- IP prefix list: prefixFilter-ab
- AS_Path list: asPathFilter-ab
Policy Value
Optional
You can configure policy values for a route as required if you set Action to Allow. Each node can have up to two policy values. You can click Add Policy Value to add policy values.- PrefVal:
PrefVal is a Huawei-specific route attribute. A larger PrefVal value indicates a higher route priority.
You can change the PrefVal value of a route by changing the PrefVal value in the route policy.
A PrefVal value must be an integer.
The default PrefVal values of routes for different types of enterprise router attachments are as follows:- Virtual gateway attachments: 100
- Peering connection attachments: 60
- VPN gateway attachments: 80
- Global DC gateway attachments: 100
NOTICE:Changing the PrefVal value of a route may adversely affect route selection of attachments. Submit a service ticket to evaluate the change.
- AS_Path attributes record the number of each AS that BGP routes pass through from the source to the destination in distance-vector order.
You can add, replace, or delete AS_Path policy values.
- Add a policy value to the left of AS_Path.
- Replace the original policy value of AS_Path.
- Delete the specified policy value of AS_Path.
AS_Path policy values must meet the following requirements:- Each value is an integer in the format of x or x.y. (x: 1 to 65535; y: 0 to 65535).
- A maximum of 10 values can be entered at a time.
- Each value must be unique.
- PrefVal: 20
- AS_Path: 2000 10.2 3.7 500
- Route type
- Click OK.
The node list is displayed. You can view the modified node.
