Creating a Global DC Gateway Attachment
You can create a Direct Connect global DC gateway attachment for an enterprise router.
After this attachment is created, you can use Direct Connect and Enterprise Router to set up a hybrid cloud network.
You need to create the global DC gateway attachment on the Direct Connect console. For details, see Creating a Global DC Gateway.
Reference
You can combine Enterprise Router and Direct Connect global DC gateways in different ways:
Setting Up a Hybrid Cloud Network Using Enterprise Router and Direct Connect Global DC Gateway
Using Enterprise Router to Migrate the Network Set Up Through Direct Connect (Global DC Gateway)
