Help Center/ Enterprise Router/ User Guide/ Flow Logs/ Viewing Details About a Flow Log
Updated on 2026-09-22 GMT+08:00
This section describes how to view details about a flow log, including the attachment ID, source/destination address, source/destination port, data packet size, and packet quantity.
By default, flow logs are generated every 10 minutes. After creating a VPC flow log, you need to wait about 10 minutes before you can view the flow log record.
  1. Go to the enterprise router list.
  2. Search for the target enterprise router by name.
  3. Click the enterprise router name and click Flow Logs.
    The flow log list is displayed.
  4. Locate the row that contains the target flow log and click View Log Record in the Operation column.
    The Log Management page is displayed.
    Figure 1 Log management
  5. In the log group list, locate the target log group and click the name of the target log stream under it.
    The log stream details page is displayed.
  6. Enter key information in the search box to quickly find the flow log to be viewed.
    Flow log format:
    <version> <project_id> <resource_id> <instance_id> <srcaddr> <dstaddr> <srcport> <dstport> <protocol> <packets> <bytes> <start> <end> <direct>
    Example 1:
    1 0605768ad980d5762f8ac010b919754c 9e00a67c-b21e-435f-9da6-20004b8392e9 a5cbd16c-7d99-4000-8f14-526ec48298ce 1.1.1.1 192.168.1.199 0 0 1 229 22442 1664007127 1664007727 ingress
    Example 2:
    1 0605768ad980d5762f8ac010b919754c 9e00a67c-b21e-435f-9da6-20004b8392e9 a5cbd16c-7d99-4000-8f14-526ec48298ce 192.168.1.199 1.1.1.1 8 0 1 229 22442 1664007127 1664007727 egress
    Table 1 describes the flow log parameters.
    Table 1 Enterprise router flow log parameters
    Example
    version
    Enterprise router flow log version
    project_id
    Project ID
    5f67944957444bd6bb4fe3b367de8f3d
    resource_id
    ID of the attachment that the traffic is generated for
    10a163ee-6efa-4e4d-9937-ead59f308497
    instance_id
    Enterprise router ID
    srcaddr
    Source IP address
    192.168.0.154
    dstaddr
    Destination IP address
    192.168.3.25
    srcport
    Source port
    38929
    dstport
    Destination port
    53
    protocol
    Internet Assigned Numbers Authority (IANA) protocol number of the traffic
    For more information, see Internet Protocol Numbers.
    17
    packets
    Number of data packets during the flow log collection
    bytes
    Size of the data packet during the flow log collection
    96
    start
    The time when the collection started, in Unix seconds
    1548752136
    end
    The time when the collection ended, in Unix seconds
    1548752736
    direct
    Traffic direction
    • ingress: traffic going into the attachment
    • egress: traffic going out of the attachment
    egress
