Updated on 2026-04-03 GMT+08:00
Supported Metrics
Function
This section describes monitoring metrics reported by Enterprise Router to Cloud Eye as well as their namespaces, metrics, and dimensions. You can use the Cloud Eye management console or APIs to obtain the monitoring metrics and alarms generated for Enterprise Router.
Cloud Eye can monitor dimensions nested to a maximum depth of four levels (levels 0 to 3). 3 is the deepest level. For example, if the monitored dimension of a metric is er_instance_id,er_attachment_id, er_instance_id indicates level 0 and er_attachment_id indicates level 1.
Namespace
SYS.ER
Metrics
You can use Cloud Eye to monitor the network status of enterprise routers and their attachments.
Table 1 Monitoring metrics of an enterprise router
Metric ID
Metric Name
Metric Description
Value Range
Unit
Conversion Rule
Monitored Object (Dimension)
Monitoring Interval (Raw Data)
instance_bytes_in
Inbound Traffic
Network traffic going into the enterprise router
≥ 0
Byte
1024 (IEC)
er_instance_id
1 minute
instance_bytes_out
Outbound Traffic
Network traffic going out of the enterprise router
≥ 0
Byte
1024 (IEC)
er_instance_id
1 minute
instance_bits_rate_in
Inbound Bandwidth
Network traffic per second going into the enterprise router
≥ 0
bit/s
1000 (SI)
er_instance_id
1 minute
instance_bits_rate_out
Outbound Bandwidth
Network traffic per second going out of the enterprise router
≥ 0
bit/s
1000 (SI)
er_instance_id
1 minute
instance_packets_in
Inbound PPS
Packets per second going into the enterprise router
≥ 0
PPS
1000 (SI)
er_instance_id
1 minute
instance_packets_out
Outbound PPS
Packets per second going out of the enterprise router
≥ 0
PPS
1000 (SI)
er_instance_id
1 minute
instance_packets_drop_blackhole
Packets Dropped by Black Hole Route
The number of packets dropped because they matched a black hole route on the enterprise router
≥ 0
Count
N/A
er_instance_id
1 minute
instance_packets_drop_noroute
Packets Dropped Due to No Matching Routes
The number of packets dropped because they did not match a route on the enterprise router
≥ 0
Count
N/A
er_instance_id
1 minute
Table 2 Monitoring metrics of an attachment
Metric ID
Metric Name
Metric Description
Value Range
Unit
Conversion Rule
attachment_bytes_in
Inbound Traffic
Network traffic going into the attachment
≥ 0
Byte
1024 (IEC)
1 minute
attachment_bytes_out
Outbound Traffic
Network traffic going out of the attachment
≥ 0
Byte
1024 (IEC)
1 minute
attachment_bits_rate_in
Inbound Bandwidth
Network traffic per second going into the attachment
≥ 0
bit/s
1000 (SI)
1 minute
attachment_bits_rate_out
Outbound Bandwidth
Network traffic per second going out of the attachment
≥ 0
bit/s
1000 (SI)
1 minute
attachment_packets_in
Inbound PPS
Packets per second going into the attachment
≥ 0
PPS
1000 (SI)
1 minute
attachment_packets_out
Outbound PPS
Packets per second going out of the attachment
≥ 0
PPS
1000 (SI)
1 minute
attachment_packets_drop_blackhole
The number of packets dropped because they matched a black hole route on the attachment
≥ 0
Count
N/A
1 minute
attachment_packets_drop_noroute
The number of packets dropped because they did not match a route on the attachment
≥ 0
Count
N/A
1 minute
If an object is in a hierarchical system, specify the monitored dimension in hierarchical form when you use an API to query the metrics of this object.
For example, to query the inbound traffic (attachment_bytes_in) of an attachment, the dimension of the metric is er_instance_id,er_attachment_id, where er_instance_id indicates level 0 and er_attachment_id indicates level 1.
  • To query a single metric by calling an API, the mount_point dimension is used as follows:
    dim.0=er_instance_id,d9f7b61f-e211-4bce-ac5f-2b76f3d0cf1d&dim.1=er_attachment_id,659614a0-e559-46c0-86ca-00c03c3d61b8
    d9f7b61f-e211-4bce-ac5f-2b76f3d0cf1d and 659614a0-e559-46c0-86ca-00c03c3d61b8 are the dimension values of er_instance_id and er_attachment_id, respectively. For details about how to obtain the values, see Dimensions.
  • To query multiple metrics by calling an API, the mount_point dimension is used as follows:
    "dimensions": [
            "name": "er_instance_id",
            "value": "d9f7b61f-e211-4bce-ac5f-2b76f3d0cf1d"
            "name": "er_attachment_id",
            "value": "659614a0-e559-46c0-86ca-00c03c3d61b8"
Dimensions
Key
Value
er_instance_id
Enterprise router ID
You can call the API Querying Enterprise Routers to obtain the value from the response parameters.
er_attachment_id
Attachment ID
You can obtain the value as follows:
  • VPC attachments: You can call the API Querying VPC Attachments to obtain the value from the response parameters.
  • Other types of attachments: You can call the API Querying Attachments to obtain the value from the response parameters.
