Stopping Sharing an Enterprise Router
If you stop share an enterprise router, the other users cannot use your enterprise router.
If you stop share an enterprise router with other users, the attachments created by the other users will not be deleted, and the other users cannot perform any operations on these attachments.
- Go to the enterprise router list.
- Search for the target enterprise router by name.
- Go to the Sharing tab using either of the following methods:
- In the upper right corner of the enterprise router, click Manage Sharing.
- Click the enterprise router name and click Sharing.
- Use either of the following methods to stop sharing an enterprise router:
- Method 1
- In the share list, locate the target share and click Stop Sharing in the Operation column.
A confirmation dialog box is displayed.
- Confirm the information and click OK.
Return to the Sharing tab. You can view that the resource share is in the Sharing stopped status.
- Method 2:
- In the share list, locate the target share and record its name.
- On the RAM console, locate the target share by name and delete the enterprise router or the users who are using the enterprise router. For details, see Updating a Resource Share.
- Method 1
