- What's New
- Function Overview
- Billing
- Getting Started
User Guide
- Permissions Management
- Enterprise Routers
- Attachments
- Route Tables
- Associations
- Propagations
- Routes
Routing Control
Route Policies
- Route Policy Overview
- Creating a Route Policy
- Associating a Route Policy with an Enterprise Router
- Changing the Route Policy Associated with an Enterprise Router
- Disassociating a Route Policy from an Enterprise Router
- Modifying a Route Policy
- Viewing a Route Policy
- Deleting a Route Policy
- Adding a Policy Node to a Route Policy
- Modifying a Policy Node in a Route Policy
- Exporting Policy Nodes in a Route Policy
- Viewing a Policy Node in a Route Policy
- Deleting a Policy Node from a Route Policy
IP Prefix Lists
- IP Prefix List Overview
- Creating an IP Prefix List
- Modifying the Name of an IP Prefix List
- Viewing an IP Prefix List
- Deleting an IP Prefix List
- Adding a Prefix Rule to an IP Address Prefix List
- Modifying an IP Prefix Rule in an IP Prefix List
- Exporting Prefix Rules in an IP Prefix List
- Viewing a Prefix Rule in an IP Prefix List
- Deleting a Prefix Rule from an IP Prefix List
AS_Path Lists
- AS_Path List Overview
- Creating an AS_Path List
- Modifying the Name of an AS_Path List
- Viewing an AS_Path List
- Deleting an AS_Path List
- Adding an AS_Path Filter to an AS_Path List
- Exporting AS_Path Filters in an AS_Path List
- Viewing an AS_Path Filter in an AS_Path List
- Deleting an AS_Path Filter from an AS_Path List
Route Policies
- Sharing
- Flow Logs
- Monitoring and Auditing
- Tags
- Quotas
Best Practices
- Summary on Enterprise Router Best Practices
- Connecting VPCs Across Regions Using Enterprise Router and Central Network
- Using Enterprise Router to Isolate VPCs in the Same Region
- Using a Third-Party Firewall to Protect VPCs Connected by Enterprise Routers
- Enabling an On-Premises Data Center to Access Service VPCs Using an Enterprise Router and Transit VPC
- Setting Up a Hybrid Cloud Network Using Enterprise Router and Direct Connect Global DC Gateway
Setting Up a Hybrid Cloud Network Using Enterprise Router and a Pair of Direct Connect Connections (Global DC Gateway)
- Overview
- Network and Resource Planning
- Process of Setting Up a Hybrid Cloud Network Using Enterprise Router and a Pair of Direct Connect Connections (Global DC Gateway)
- Procedure for Setting Up a Hybrid Cloud Network Using Enterprise Router and a Pair of Direct Connect Connections (Global DC Gateway)
Setting Up a Hybrid Cloud Network Using Enterprise Router and a Pair of Active/Standby Direct Connect Connections (Global DC Gateway)
- Overview
- Process of Setting Up a Hybrid Cloud Network Using Enterprise Router and a Pair of Active/Standby Direct Connect Connections (Global DC Gateway)
- Procedure for Setting Up a Hybrid Cloud Network Using Enterprise Router and a Pair of Active/Standby Direct Connect Connections (Global DC Gateway)
- Setting Up a Hybrid Cloud Network Using Enterprise Router, VPN, and Direct Connect (Global DC Gateway)
- Setting Up a Hybrid Cloud Network Using Enterprise Router and Direct Connect (Virtual Gateway)
- Setting Up a Hybrid Cloud Network Using Enterprise Router and a Pair of Direct Connect Connections (Virtual Gateway)
- Setting Up a Hybrid Cloud Network Using Enterprise Router, VPN, and Direct Connect (Virtual Gateway)
- Allowing VPCs to Share an EIP to Access the Internet Using Enterprise Router and NAT Gateway
- Using Enterprise Router to Migrate the Network Set Up Through VPC Peering
- Using Enterprise Router to Migrate the Network Set Up Through Direct Connect (Global DC Gateway)
- Using Enterprise Router and Central Network to Migrate the Network Set Up Through a Cloud Connection
- API Reference
- FAQs
More Documents
- Getting Started
- Attachments
- Route Tables
- Associations
- Propagations
- Routes
- Sharing
- Flow Logs
- Monitoring
- Interconnecting with CTS
- Tags
- Quotas
- FAQ
- Change History
User Guide (Ankara Region)
- Getting Started
- Attachments
- Route Tables
- Associations
- Propagations
- Routes
- Sharing
- Flow Logs
- Monitoring
- Quotas
- FAQ
- Change History
- API Reference (Ankara Region)
Show all
Key Operations Recorded by CTS
An enterprise router is a central router that interconnects all of your VPCs and on-premises networks.
With CTS, you can record operations associated with your enterprise routers for future query, audit, and backtracking.
Operation |
Resource Type |
Trace Name |
Creating an enterprise router |
erInstance |
createInstance |
Modifying an enterprise router |
erInstance |
updateInstance |
Deleting an enterprise router |
erInstance |
deleteInstance |
Querying the enterprise router list |
erInstance |
listEnterpriseRouters |
Viewing an enterprise router |
erInstance |
showEnterpriseRouter |
Adding attachments to an enterprise router |
erAttachment |
createAttachment |
Creating a peering connection attachment |
erAttachment |
createPeeringAttachment |
Creating a VPC attachment |
erAttachment |
createVpcAttachment |
Modifying an Attachment |
erAttachment |
updateAttachment |
Modifying a VPC attachment |
erAttachment |
updateVpcAttachment |
Deleting an attachment |
erAttachment |
deleteAttachment |
Deleting a peering connection attachment |
erAttachment |
deletePeeringAttachment |
Deleting a VPC attachment |
erAttachment |
deleteVpcAttachment |
Accepting an attachment request |
erAttachment |
acceptAttachment |
Rejecting an attachment request |
erAttachment |
rejectAttachment |
Viewing the attachment list |
erAttachment |
listAttachments |
Viewing details about an attachment |
erAttachment |
showAttachment |
Creating a route table |
erRouteTable |
createRouteTable |
Modifying a route table |
erRouteTable |
updateRouteTable |
Deleting a route table |
erRouteTable |
deleteRouteTable |
Querying the route table list |
erRouteTable |
listRouteTables |
Viewing a route table |
erRouteTable |
showRouteTable |
Creating a static route |
erStaticRoute |
createStaticRoute |
Batch creating static routes |
erStaticRoute |
batchCreateStaticRoute |
Deleting a static route |
erStaticRoute |
deleteStaticRoute |
Batch deleting static routes |
erStaticRoute |
batchDeleteStaticRoute |
Modifying a static route |
erStaticRoute |
updateStaticRoute |
Querying static routes |
erStaticRoute |
listStaticRoutes |
Viewing a static route |
erStaticRoute |
showStaticRoute |
Creating an association |
erAssociation |
createAssociation |
Deleting an association |
erAssociation |
deleteAssociation |
Querying associations in a route table |
erAssociation |
listAssociations |
Creating a propagation |
erPropagation |
createPropagation |
Deleting a propagation |
erPropagation |
deletePropagation |
Querying a propagation in a route table |
erPropagation |
listPropagations |
Creating a flow log |
erFlowLog |
createFlowLog |
Modifying a flow log |
erFlowLog |
updateFlowLog |
Disabling flow logging |
erFlowLog |
updateFlowLog |
Enabling flow logging |
erFlowLog |
updateFlowLog |
Deleting a flow log |
erFlowLog |
deleteFlowLog |
Querying the flow log list |
erFlowLog |
listFlowLogs |
Viewing a flow log |
erFlowLog |
showFlowLog |
