Updated on 2025-04-23 GMT+08:00
Adding a Tag to a Route Table
Add a tag to an existing route table.
- Go to the enterprise router list.
- Search for the target enterprise router by name.
- Click the enterprise router name and click the Route Tables tab.
The route table list is displayed.
- Click the target route table. On the Tags tab, click Edit Tag.
The Edit Tag page is displayed.
- Perform the following operations as required:
- Adding a tag: Click
, enter a tag key and value, and click OK.
- Modifying a tag: Click
next to the target tag key or value, delete the original value, enter a new value, and click OK.
- Deleting a tag: Click Delete next to the target tag and click OK.
Parent topic: Adding a Tag
