Help Center/
Enterprise Router/
User Guide/
Tags/
Adding a Tag/
Adding a Tag to an Enterprise Router
Updated on 2025-04-23 GMT+08:00
Add a tag to an existing enterprise router.
- Go to the enterprise router list.
- Search for the target enterprise router by name.
- Click the name of the enterprise router.
The page about the enterprise router details is displayed.
- Click the Tags tab and then click Edit Tag in the upper left corner above the tag list.
The Edit Tag page is displayed.
- Perform the following operations as required:
- Adding a tag: Click
, enter a tag key and value, and click OK.
- Modifying a tag: Click
next to the target tag key or value, delete the original value, enter a new value, and click OK.
- Deleting a tag: Click Delete next to the target tag and click OK.
Parent topic: Adding a Tag
