Updated on 2025-03-06 GMT+08:00
Deleting a VPC Attachment
This section describes how to delete a VPC attachment from an enterprise router.
- Deleting a VPC attachment will also delete its associations, propagations, and propagated routes in the route table.
- If a VPC attachment is deleted, the next hop of its related static routes will be Blackhole. If the destination of a packet matches the blackhole route, the packet will be discarded.
- If flow logging is enabled for a VPC attachment, flow logging will be disabled, but collected flow logs will not be deleted.
- Go to the enterprise router list.
- Search for the target enterprise router by name.
- Go to the Attachments tab using either of the following methods:
- In the upper right corner of the enterprise router, click Manage Attachment.
- Click the enterprise router name and click Attachments.
- In the attachment list, locate the target VPC attachment, and click Delete in the Operation column.
A confirmation dialog box is displayed.
- Confirm the information and click OK.
A deleted attachment cannot be recovered.
Parent topic: VPC Attachments
