Help Center/ Enterprise Router/ User Guide/ Routes/ Deleting a Static Route
Updated on 2025-07-31 GMT+08:00
Delete a static route from a route table of an enterprise router.
Only static routes can be deleted. To delete a propagated route, you need to delete its propagation. The route will be deleted together with the propagation. For details, see Deleting a Propagation from a Route Table.
  1. Go to the enterprise router list.
  2. Search for the target enterprise router by name.
  3. Go to the Route Tables tab using either of the following methods:
    • In the upper right corner of the enterprise router, click Manage Route Table.
    • Click the enterprise router name and click Route Tables.
  4. Click the route table where you want to delete a route. On the Routes tab, locate the route and click Delete in the Operation column.
    A confirmation dialog box is displayed.
  5. Confirm the information and click OK.
    A deleted static route cannot be recovered.
    Wait for 2 to 3 seconds, and click to refresh the route list. The route does not exist in the list.
