Deleting a Propagation from a Route Table
You can delete a propagation between an attachment and an enterprise router route table from the enterprise router route table.
Deleting a propagation between an attachment and an enterprise router route table will also delete the attachment routes that were automatically learned through that propagation. Propagated routes are learned through propagation.
- Go to the enterprise router list.
- Search for the target enterprise router by name.
- Go to the Route Tables tab using either of the following methods:
- In the upper right corner of the enterprise router, click Manage Route Table.
- Click the enterprise router name and click Route Tables.
- Click the route table where you want to delete a propagation. On the Propagations tab, locate the propagation you want to delete and click Delete in the Operation column.
A confirmation dialog box is displayed.
- Confirm the information and click OK.
A deleted propagation cannot be recovered.
