Help Center/ Enterprise Router/ User Guide/ Associations/ Deleting an Association from a Route Table
Updated on 2025-07-31 GMT+08:00
This section describes how to delete an association from the route table of an enterprise router.
  1. Go to the enterprise router list.
  2. Search for the target enterprise router by name.
  3. Go to the Route Tables tab using either of the following methods:
    • In the upper right corner of the enterprise router, click Manage Route Table.
    • Click the enterprise router name and click Route Tables.
  4. Click the route table that you want to delete an association from. On the Associations tab, locate the association you want to delete and click Delete in the Operation column.
    A confirmation dialog box is displayed.
  5. Confirm the information and click OK.
    A deleted association cannot be recovered.
