Deleting a Route Table
Delete an enterprise router route table that is no longer needed.
- If a route table is used as the default association route table and/or default propagation route table, the route table cannot be deleted.
- If Default Route Association is set to Yes on the basic information page of the route table, the route table is used as the default association route table.
- Also, if Default Route Propagation is set to Yes on the basic information of the route table, the route table is used as the default propagation route table.
To delete such a route table, change Default Route Association and Default Route Propagation settings. For details, see Modifying an Enterprise Router.
- A route table cannot be deleted if it contains an association or a propagation. You need to delete the association and propagation before deleting this route table.
- For details about how to delete an association, see Deleting an Association from a Route Table.
- For details about how to delete a propagation, see Deleting a Propagation from a Route Table.
- A route table can be deleted if it contains only static routes. Ensure that the routes are no longer required before deleting their route table.
- Go to the enterprise router list.
- Search for the target enterprise router by name.
- Go to the Route Tables tab using either of the following methods:
- In the upper right corner of the enterprise router, click Manage Route Table.
- Click the enterprise router name and click Route Tables.
- In the route table list, click
next to the name of the target route table.
A confirmation dialog box is displayed.
- Confirm the information and click OK.
A deleted route table cannot be recovered.
