Attachment Overview
        Attachment Type  |
        Network Instance  |
        Creating Attachments  |
        Viewing Attachments  |
        Deleting Attachments  |
        VPC attachment  |
        VPC  |
        Virtual gateway attachment  |
        Virtual gateway of Direct Connect  |
        VPN gateway attachment  |
        VPN gateway  |
        Peering connection attachment  |
        Enterprise routers in other regions. You can add enterprise routers from different regions to a central network as attachments. Each connection between enterprise routers is a peering connection attachment.  |
        Global DC gateway attachment  |
        Global DC gateway in Direct Connect  |
        CFW instance attachment  |
        VPC border firewall  |
   If you need to set up a hybrid cloud network, it is recommended that you use Enterprise Router and Direct Connect Global DC Gateway.
From May 2024, enterprise routers and Direct Connect virtual gateways cannot be used together to set up a hybrid cloud network. Existing networks that are set up using enterprise routers and Direct Connect virtual gateways are not affected.
