Configuring SSO
Single Sign-On (SSO) allows users to log in once through an IdP and seamlessly access trusted Service Provider (SP) systems via redirect links.
For example, once an enterprise management system establishes a trust relationship with Huawei Cloud, enterprise users can log in to their local system with existing credentials and access CodeArts Agent seamlessly. These users are called federated users.
CodeArts Agent supports SSO based on SAML and OpenID Connect (OIDC).
You have purchased the CodeArts Agent Professional Edition package.
Configuring SSO
- Use an HUAWEI ID to configure an IdP on the IAM console. For details, see Identity Providers.
- Log in to the CodeArts Agent console as a federated user via SSO.
The login-free validity period of federated users is 24 hours. Once a federated user logged in, the client automatically maintains their login status for up to 24 hours, provided there is a stable network connection.
