30-Day Login-Free
The CodeArts Agent client supports the 30-day login-free function. Account: After your initial login, reopening the client within 30 days will automatically keep you logged in, as long as you are connected to the network. IAM user: The login-free validity period is 24 hours.
To grant an IAM user the 30-day login-free permissions, you need to log in using the HUAWEI ID and configure the identity policy. If the identity policy is not configured, a message is displayed on the login page.
This section describes how to use a HUAWEI ID to configure a 30-day login-free identity policy and apply the policy to an IAM user. After the policy is applied, the IAM user can obtain the 30-day login-free permission.
Only HUAWEI IDs and IAM user accounts support the 30-day login-free function.
Configuring an Identity Policy
- Use a HUAWEI ID to log in to the IAM console (new edition).
- In the navigation tree on the left, click Identity Policies. The identity policy page is displayed.
- Click Create Identity Policy in the upper right corner.
- Set the custom identity policy by referring to Table 1.
Table 1 Parameters for custom identity policies Parameter
Policy Name
Enter an identity policy name. Only letters, digits, and the following special characters are allowed: +=_.@-
Policy View
Select Visual editor.
Policy Content
- Select Allow.
- Click Select service. Select signin.
- Click Select action. Select signin::authorizeOAuth2Access and signin::createOauth2Token.
- Skip Select resource.
- Skip Add Request Condition.
Optional. Enter a brief description for the policy.
Figure 2 Creating an identity policy
- Click OK.
The new policy is displayed on the Identity Policies page.
- Assign the identity policy to an IAM user or user group. For details, see Assigning Permissions to an IAM User or Creating a User Group and Assigning Permissions. Once the policy is assigned, it may take 15 to 30 minutes to take effect.
- If IAM users log in to CodeArts Agent for the first time after the authorization takes effect, they can access the service without a login within 30 days.
- If IAM users have logged in to CodeArts Agent before the authorization takes effect, they must log out and log back to enable the 30-day login-free function.
