My Token Usage
You can view the token usage statistics of your own, including your activeness and resource consumption on the CodeArts Agent console.
If you want to view the team usage, see Data Analytics.
Data on this page is automatically updated every hour.
Viewing Usage Details
- Log in to the CodeArts Agent console as an Enterprise administrator or Enterprise member.
- In the navigation tree on the left, choose My Space > My Token Usage. The My Token Usage page is displayed.
- Refer to Table 1 to view the token usage, pay-per-use usage, and activity heatmap.
Table 1 Token usage overview Item
Personal Token Usage
Displays the number of tokens consumed by the current account on CodeArts Agent. Only the consumptions of the built-in models are collected.
Pay-per-Use
After the pay-per-use billing mode is enabled, the tokens used totally and the tokens used in this month are displayed.
Active Heat Map
Displays daily activity for the past 12 months or selected calendar years. Darker colors indicate higher daily token consumption. It covers the token consumption of built-in models and custom models.
- Set the time range, and select the models and functions. Click
to view the personal usage in different scenarios. Figure 1 Personal usage dashboard
Table 2 Personal usage dashboard Item
Tokens Used
Displays the combined number of input and output tokens consumed by the built-in and custom agents within the selected range.
Daily Average Tokens Used
Displays the daily average of tokens consumed by the built-in and custom agents within the selected range.
Active Days
Displays how many days agents are used at least once within the selected range.
Requests
Displays the total number of requests of using all functions within the selected range.
Token Trend
Displays the total token consumptions, cached tokens, input tokens, and output tokens by day, week, or month within the selected range.
Top Models
Displays the usage percentage of built-in models and custom models within the selected range, reflecting the model usage preference.
Top Functions
Displays the usage percentage of each product function within the selected range.
Code Generation
Displayed only when both of the following conditions are met:
- All agents are selected.
- All functions are selected, or the Code completion function is selected.
Displays the total lines generated, total lines accepted, total generations, total acceptances, and acceptance rate within the selected range.
