Data Analytics
CodeArts Agent provides team-oriented analytics with comprehensive insights into team usage, highlighting team activity, resource consumption, and key statistics. The enterprise administrator can view detailed team data on the Data Analytics page.
For details about how to view personal usage, see My Token Usage.
The data provided on the Data Analytics page is automatically updated every hour.
Viewing Data
- Log in to the CodeArts Agent console as an Enterprise Administrator.
- In the navigation tree on the left, choose Enterprise Management > Data Analytics.
- Set the time range, and select the teams, models, and functions. Click
to view the team data in different scenarios.
The data on this page is updated automatically every hour. Consequently, data cannot be displayed in real time, for example, any new team you create will not appear in the selection list until the next automatic update.
Figure 1 Data analytics
Table 1 Data analytics dashboard Item
Enabled Members
Displays the number of users with enabled seats within the selected range.
Active Members
Displays how many users have sent at least one prompt to the agent within the selected range.
Total Tokens Used
Displays the combined number of input and output tokens consumed by the built-in and custom agents within the selected range.
Daily Average Tokens Used
Displays the daily average of input and output tokens consumed by the built-in and custom agents within the selected range.
Trends
Displays the trends of the daily, weekly, or monthly token consumptions, cached tokens, or the number of active members.
Top Teams
Displays the teams sorted by the selected indicator, such as used tokens, cached tokens, and active members, within the selected range to identify high-active or high-value teams.
Top Models
Displays the usage percentage of built-in models and custom models within the selected range.
Top Functions
Displays the usage percentage of each product function within the selected range.
