Supported Cloud Services
You can go to EPS console to check services and resources supported by EPS.
On the Enterprise Project Management Service page of EPS console, you can click View Resource in the Operation column of any projects to view services and resources supported by EPS.
There may be multiple versions of a service, and only one version is supported by Enterprise Project Management. Enterprise Project Management console only displays service and resource types that are supported. For details about version information, see related documentation of each service.
The following table lists the cloud services and resources supported by EPS.
| Service | Resource Type |
| Direct Connect |
| Elastic Cloud Server (ECS) | Elastic cloud server |
| Bare Metal Server (BMS) | Bare metal server |
| Auto Scaling (AS) | AS group |
| Image Management Service (IMS) | Private image |
| Dedicated Host (DeH) | Dedicated host |
| FunctionGraph | Function |
| Object Storage Service (OBS) | Bucket |
| Elastic Volume Service (EVS) | Disk |
| Cloud Backup and Recovery (CBR) | Vault |
| Content Delivery Network (CDN) | Domain name |
| Scalable File Service (SFS) | File system |
| Scalable File Service Turbo (SFS Turbo) | SFS Turbo |
| Virtual Private Cloud (VPC) |
| Bandwidth | Shared bandwidth |
| Elastic IP (EIP) | Elastic IP |
| Elastic Load Balance (ELB) | Load balancer |
| NAT Gateway | Public NAT gateway |
| Domain Name Service (DNS) |
| Cloud Container Engine (CCE) |
| Cloud Container Instance (CCI) | Namespace |
| Gene Container Service (GCS) | Environment |
| Advanced Anti-DDoS (AAD) | Instance |
| Web Application Firewall (WAF) |
| Host Security Service (HSS) | Host security |
| Key Management Service (KMS) | Key |
| Distributed Cache Service (DCS) | Instance |
| Distributed Message Service (DMS) |
| Simple Message Notification (SMN) | Topic |
| Blockchain Service (BCS) |
| API Gateway (APIG) | Dedicated gateway |
| Cloud Eye |
| Application Operations Management (AOM) | Resource group |
| Application Performance Management (APM) | Application |
| Log Tank Service (LTS) | Log stream |
| Cloud Connect (CC) |
| Relational Database Service (RDS) | Instance |
| Document Database Service (DDS) | Instance |
| Distributed Database Middleware (DDM) | Instance |
| Data Replication Service (DRS) |
| GaussDB | GaussDB instance |
| Cloud Data Migration (CDM) | Cluster |
| ModelArts | Workspace |
| MapReduce Service (MRS) | Cluster |
| Data Lake Insight (DLI) |
| Cloud Search Service (CSS) | Cluster |
| Data Warehouse Service (DWS) | DWS cluster |
| Data Ingestion Service (DIS) | Stream |
| CloudTable | CloudTable cluster |
| Graph Engine Service (GES) | GES cluster |
| Recommender System (RES) | Workspace |
| Data Lake Visualization (DLV) | DLV instance |
| DevCloud | Project management |
| ROMA Connect |
| SupportPlan Service | Support plan |
| Cloud Service Engine (CSE) | Engine |
| Private Number | Application |
| SSL Certificate Manager (SCM) | Certificate |
| DataArts Studio (DAYU) | DAYU instance |
| Dedicated Distributed Storage Service (DSS) |
| Dedicated Computing Cluster (DCC) | Dedicated computing cluster |
| Server Migration Service (SMS) | Source server |
| Application Service Mesh (ASM) | Mesh |
| Database Security Service (DBSS) | Database audit instance |
| Virtual Private Network (VPN) | VPN gateway |
| Video on Demand (VOD) | Domain name |
| Database and Application Migration UGO (UGO) |
| Enterprise Web Portal | Site |
| Multi-Cloud High Availability Service |
| Enterprise Router (ER) | Enterprise router |
| Change Management Service (CMS) |
| Private Certificate Authority (PCA) |
| Cloud Phone Host (CPH) | Cloud phone server |
| MacroVerse SmartStage for Integrators | Flow |
| Cloud Trace Service (CTS) | Tracker |
| Cloud Bastion Host (CBH) | Bastion host |
| Cloud Firewall (CFW) | Cloud firewall |
| Live | Domain |
| Cloud-native Anti-DDoS | CNAD |
| IoT Device Access (IoTDA) | Instance |
| Dedicated HSM | Hardware security module |
| Cloud Secret Management Service (CSMS) | Secret |
| LakeFormation | LakeFormation instance |
| Edge Security |
| Workspace | Workspace-desktop |
| Enterprise Connect |
| EventGrid (EG) | Channel |
| Global Elastic IP |
| Industrial Digital Model Engine (iDME) |
| Global Accelerator (GA) | Accelerator |
| Industrial Simulation Cloud Service |
| Integrated Product DevelopmentCenter Cloud Service | DigitalProductServices |
| ServiceStage |
| GeminiDB | Instance |
