Adding Resources to an Enterprise Project
Updated on 2024-09-20 GMT+08:00
You can add resources to or remove resource from enterprise projects as needed.
An enterprise project can contain resources from different regions.
Restrictions and Limitations
  • Currently, resources can only be transferred between commercial projects or test projects.
  • Enterprise projects are commercial projects by default. You cannot transfer the resources of a default enterprise project to a test project.
  • You cannot add resources or user groups to a disabled enterprise project.
  1. Sign in to the management console.
  2. Choose Enterprise > Project Management in the upper right corner of the page.
    If the screen resolution is low, choose More > Enterprise > Project Management.
    Figure 1 Project Management
  3. On the Enterprise Project Management Service page, click View Resource in the Operation column of the row containing the target enterprise project.
    The enterprise project details page is displayed. You can view the resources in the enterprise project on the Resources tab.
    Figure 2 Viewing resources
  4. Click Add.
    The Add Resource dialog box is displayed.
    Figure 3 Accessing the Add Resource dialog box
  5. Select a mode.
    • Independent resources: Each resource is added as an independent resource, and multiple resources can be added at a time.
      Select this mode when adding resources other than ECSs.
      If you select this mode to add ECSs, their associated resources, such as EIPs and EVS disks, will not be added.
    • ECSs and ECS associated resources: Only ECSs need to be selected. Resources associated with the selected ECSs will be automatically added to the enterprise project at the same time.
      Select this mode when adding ECSs and their associated resources. Currently, only EVS disks and EIPs can be added together with ECSs.
  6. Filter resources by service, region, or enterprise project in the filter box above the resource list, or enter a resource name in the search box for exact search.
    Disabled enterprise projects and enterprise of different types are not displayed in the drop-down list.
  7. For services that contain multiple resource types, you can click next to Resource Type to filter resources.
    Resources meeting the search criteria are displayed in the lower part of the page.
    If you select ECSs and ECS associated resources for Mode, you cannot filter resources by service or resource type.
    Figure 4 Add Resource
  8. Select the resources to be added and click OK.
    After the resources are added, they appear in the resource list of the current enterprise project.
