Viewing Resources in an Enterprise Project
You can view all resources of an enterprise project. For details about how to export resource information for an enterprise project, see Exporting Resource Information.
- Sign in to the management console.
- Choose Enterprise > Project Management in the upper right corner of the page.
If the screen resolution is low, choose More > Enterprise > Project Management.
Figure 1 Project Management - On the Enterprise Project Management Service page, click View Resource in the Operation column of the row containing the target enterprise project.
The enterprise project details page is displayed. You can view the resources in the enterprise project on the Resources tab.
Figure 2 Viewing resources - Set search options.
- Select regions.
- Select services.
After you select services, you can further specify resource types accordingly.
To view all resources of an enterprise project, select All for both the Region and Service.
If you select EIP for Service, you can view associated instances. The instances can only be ECSs, enhanced load balancers, BMSs, and virtual IP addresses.
- Click Search and the resources will be displayed in a table at the bottom of the page.
EPS does not support exporting resource information. To export resource information, go to Config console. For more details, see Exporting the Resource List.
