Updated on 2025-11-04 GMT+08:00
Creating an Enterprise Project
The following procedure shows how to create an enterprise project (project_A). You can follow the procedure to create more projects, such as project_B.
  1. Log in to Huawei Cloud console.
  2. Choose Enterprise > Project Management in the upper right corner of the page.
    If the screen resolution is low, choose More > Enterprise > Project Management.
    Figure 1 Project Management
  3. On the Enterprise Project Management Service page, click Create Enterprise Project in the upper right corner.
    The Create Enterprise Project dialog box is displayed.
    Figure 2 Creating an enterprise project
  4. Select a project type based on service requirements.
  5. Set Name and Description, and click OK.
    Table 1 Configuration rules
    Example
    Name
    Name of the enterprise project you create.
    A project name can contain up to 255 characters. Only letters, digits, underscores (_), and hyphens (-) are allowed. It cannot contain the word default in any form.
    project_A
    Description of the enterprise project.
    The description can contain up to 512 characters.
    Manage the resources in this enterprise project.
