Help Center/
Enterprise Management/
User Guide/
Project Management/
Getting Started/
Creating a User Group
Updated on 2025-11-24 GMT+08:00
The following procedure shows how to create a user group, such as Test_ECS_A. You can follow the procedure to create more user groups, such as Test_ECS_B.
- Log in to Huawei Cloud console.
- On the management console, point to the username in the upper right corner, and choose Identity and Access Management from the drop-down list.
- In the navigation pane on the left, click User Groups. Click Create User Group in the upper right corner.
Figure 1 Creating a user group
- On the displayed page, enter a user group name, for example, Test_ECS_A.
Figure 2 Entering the name of the user group
- Click OK.
The user group you create is displayed in the user group list.
Parent topic: Getting Started
