Updated on 2026-05-21 GMT+08:00
Auditing and Logging
Cloud Trace Service (CTS) is a log audit service for Huawei Cloud security. It allows you to collect, store, and query cloud resource operation records. You can use these records for security analysis, audit compliance, resource tracking, and fault locating.
After CTS is enabled, EPS operations can be recorded for auditing.
  • For details about how to enable and configure CTS, see Enabling CTS.
  • For details about how to view traces, see Querying Real-Time Traces.
  • The following table lists the operation events that can be audited by EPS.
    Table 1 EPS operations recorded by CTS
    Operation
    Resource Type
    Trace Name
    Creating an enterprise project
    enterpriseProject
    createEnterpriseProject
    Modifying an enterprise project
    enterpriseProject
    modifyEnterpriseProject
    Disabling an enterprise project
    enterpriseProject
    disableEnterpriseProject
    Enabling an enterprise project
    enterpriseProject
    enableEnterpriseProject
    Migrating resources
    You can perform this operation by calling an API. Currently, EPS console does not support this operation.
    enterpriseProjectResource
    migrate
    Removing resources and their associated resources
    associatedMigrateOut
    Adding resources and their associated resources
    associatedMigrateIn
    Adding resources to an enterprise project.
    migrateIn
    Removing resources
    migrateOut
