Updated on 2025-11-24 GMT+08:00
Disabling Enterprise Center
If you no longer use Enterprise Center, you can disable it on the Overview page.
Precautions
  • Disabling Enterprise Center causes expenditure and budget data of the enterprise to be permanently deleted. The data cannot be restored even if the enterprise master account is re-enabled.
  • Disabling Enterprise Center will also delete all organizations created by the master account.
No valid member accounts are associated with the enterprise master account.
  1. Go to the Overview page.
  2. Click Disable Enterprise Center in the upper right corner.
    If the enterprise master account is associated with any member accounts, click Disassociate and disassociate it from all member accounts on the Organizations and Accounts page.
  3. Click Yes. The enterprise center is disabled successfully.
