Help Center/
Elastic Load Balance/
User Guide/
User Guide for Shared Load Balancers/
Listener/
Deleting a Listener
Updated on 2025-08-05 GMT+08:00
Deleting a Listener
You can modify a listener as needed or delete a listener if you no longer need it.
Deleted listeners cannot be recovered.
If modification protection is enabled for a listener, the listener cannot be deleted or modified.
- Go to the load balancer list page.
- On the displayed page, locate the load balancer and click its name.
- Deleting a listener:
- On the Listeners tab, locate the listener, and click Delete in the Operation column.
- In the displayed dialog box, enter DELETE.
- Batch deleting listeners:
- On the Listeners tab, select multiple listeners you want to delete.
- Click Delete above the listener list.
- Click OK.
