Updated on 2025-05-09 GMT+08:00
Managing Certificates
You can manage your certificates on the ELB console. If a certificate is no longer needed, you can delete it.
Notes and Constraints
A certificate that has been bound to an HTTPS listener cannot be deleted. Disassociate the certificate from the listener first by referring to Replacing a Certificate.
Querying Listeners by Certificate
  1. Go to the load balancer list page.
  2. In the navigation pane on the left, choose Certificates.
  3. In the certificate list, click the listener name in the Listener (Frontend Protocol/Port) column to view its details.
    If there are more than 5 listeners, no listener is displayed in the Listener (Frontend Protocol/Port) column. Click View All. On the displayed page, click Listeners, locate the listener, and click its name to view it details.
Modifying a Certificate
  3. Locate the certificate and click Modify in the Operation column.
  4. In the Modify Certificate dialog box, modify the parameters as required.
  5. Confirm the information and click OK.
Deleting a Certificate
  3. Locate the certificate and click Delete in the Operation column.
  4. In the displayed dialog box, click OK.
