Updated on 2026-07-07 GMT+08:00
TLS Security Policy
HTTPS encryption is commonly used for applications that require secure data transmission, such as banks and finance. When you add HTTPS listeners, you can select appropriate default security policies to improve security. A security policy is a combination of TLS protocols of different versions and supported cipher suites.
You can only select the default security policies for HTTPS listeners added to a shared load balancer.
Adding a Security Policy
  1. Go to the load balancer list page.
  2. On the displayed page, locate the load balancer and click its name.
  3. Under Listeners, click Add Listener.
  4. On the Add Listener page, set Frontend Protocol to HTTPS.
  5. On the Add Listener dialog box, click More (Optional) and specify Security Policy.
    Table 1 lists the default security policies supported by shared load balancers.
    Table 1 Default security policies
    Name
    TLS Versions
    Cipher Suites
    tls-1-0
    TLS 1.2
    TLS 1.1
    TLS 1.0
    • ECDHE-RSA-AES256-GCM-SHA384
    • ECDHE-RSA-AES128-GCM-SHA256
    • ECDHE-ECDSA-AES256-GCM-SHA384
    • ECDHE-ECDSA-AES128-GCM-SHA256
    • AES128-GCM-SHA256
    • AES256-GCM-SHA384
    • ECDHE-ECDSA-AES128-SHA256
    • ECDHE-RSA-AES128-SHA256
    • AES128-SHA256
    • AES256-SHA256
    • ECDHE-ECDSA-AES256-SHA384
    • ECDHE-RSA-AES256-SHA384
    • AES128-SHA
    • AES256-SHA
    tls-1-1
    TLS 1.2
    TLS 1.1
    tls-1-2
    TLS 1.2
    tls-1-2-strict
    TLS 1.2
    • AES128-GCM-SHA256
    • AES256-GCM-SHA384
    • AES128-SHA256
    • AES256-SHA256
    • Shared load balancers support TLS 1.2 or earlier versions.
    • The above table lists the cipher suites supported by ELB. Generally, clients also support multiple cipher suites. In actual use, the cipher suites supported by both ELB and clients are used, and the cipher suites supported by ELB take precedence.
  6. Confirm the configurations and go to the next step.
Differences Between Security Policies
Table 2 Differences between the security policies
Security Policy
tls-1-0
tls-1-1
tls-1-2
tls-1-2-strict
TLS version
Protocol-TLS 1.3
N/A
N/A
N/A
N/A
Protocol-TLS 1.2
Supported
Supported
Supported
Supported
Protocol-TLS 1.1
Supported
Supported
N/A
N/A
Protocol-TLS 1.0
Supported
N/A
N/A
N/A
Cipher suite
EDHE-RSA-AES128-GCM-SHA256
Supported
Supported
Supported
Supported
Supported
Supported
Supported
Supported
Supported
Supported
Supported
Supported
Supported
Supported
Supported
Supported
AES128-GCM-SHA256
Supported
Supported
Supported
Supported
AES256-GCM-SHA384
Supported
Supported
Supported
Supported
AES128-SHA256
Supported
Supported
Supported
Supported
AES256-SHA256
Supported
Supported
Supported
Supported
Supported
Supported
Supported
N/A
Supported
Supported
Supported
N/A
AES128-SHA
Supported
Supported
Supported
N/A
AES256-SHA
Supported
Supported
Supported
N/A
Supported
Supported
Supported
Supported
Supported
Supported
Supported
Supported
Supported
Supported
Supported
N/A
Supported
Supported
Supported
Supported
Supported
Supported
Supported
Supported
Supported
Supported
Supported
N/A
N/A
N/A
N/A
N/A
TLS_AES_256_GCM_SHA384
N/A
N/A
N/A
N/A
TLS_CHACHA20_POLY1305_SHA256
N/A
N/A
N/A
N/A
TLS_AES_128_GCM_SHA256
N/A
N/A
N/A
N/A
TLS_AES_128_CCM_8_SHA256
N/A
N/A
N/A
N/A
TLS_AES_128_CCM_SHA256
N/A
N/A
N/A
N/A
DHE-RSA-AES128-SHA
N/A
N/A
N/A
N/A
DHE-DSS-AES128-SHA
N/A
N/A
N/A
N/A
CAMELLIA128-SHA
N/A
N/A
N/A
N/A
EDH-RSA-DES-CBC3-SHA
N/A
N/A
N/A
N/A
DES-CBC3-SHA
N/A
N/A
N/A
N/A
ECDHE-RSA-RC4-SHA
N/A
N/A
N/A
N/A
RC4-SHA
N/A
N/A
N/A
N/A
DHE-RSA-AES256-SHA
N/A
N/A
N/A
N/A
DHE-DSS-AES256-SHA
N/A
N/A
N/A
N/A
DHE-RSA-CAMELLIA256-SHA
N/A
N/A
N/A
N/A
ECC-SM4-SM3
N/A
N/A
N/A
N/A
ECDHE-SM4-SM3
N/A
N/A
N/A
N/A
Changing a Security Policy
When you change a security policy, ensure that the security group rules configured for backend servers allow traffic from 100.125.0.0/16 to backend servers and allows ICMP packets for UDP health checks. Otherwise, backend servers will be considered unhealthy, resulting in service interruptions.
  3. On the Listeners tab, locate the listener, and click its name.
  4. On the Summary tab, click Edit on the top right.
  5. In the Edit dialog box, expand Advanced Settings (Optional) and change the security policy.
  6. Click OK.
