Updated on 2025-05-09 GMT+08:00
Monitoring Metrics
Overview
This section describes the namespace, the metrics that can be monitored by Cloud Eye, and dimensions of these metrics. You can view the metrics reported by ELB and the generated alarms on the Cloud Eye console.
Namespace
SYS.ELB
Load Balancer Metrics
For shared load balancers, you can view the monitoring metrics by load balancer or listener.
Table 1 Metrics supported by each shared load balancer
Metric ID
Name
Value Range
Unit
Conversion Rule
Monitored Object (Dimension)
Monitoring Interval
(Raw Data)
m1_cps
Concurrent Connections
Load balancing at Layer 4: total number of TCP and UDP connections established between the monitored object and backend servers.
Load balancing at Layer 7: total number of TCP connections established between the clients and the monitored object.
≥ 0
Count
N/A
Shared load balancer
1 minute
m2_act_conn
Active Connections
The number of active TCP and UDP connections established between the monitored object and backend servers.
You can run the following command to view the connections (both Windows and Linux servers):
netstat -an
≥ 0
Count
N/A
1 minute
m3_inact_conn
Inactive Connections
The number of inactive TCP and UDP connections established between the monitored object and backend servers.
netstat -an
≥ 0
Count
N/A
1 minute
m4_ncps
New Connections
The number of new connections established between clients and the monitored object per second.
≥ 0
Count/s
N/A
1 minute
m5_in_pps
Incoming Packets
The number of packets received by the monitored object per second.
≥ 0
Count/s
N/A
1 minute
m6_out_pps
Outgoing Packets
The number of packets sent from the monitored object per second.
≥ 0
Count/s
N/A
1 minute
m7_in_Bps
Inbound Traffic Rate
How fast the inbound traffic reaches the monitored object.
≥ 0
Byte/s
1000 (SI)
1 minute
m8_out_Bps
Outbound Traffic Rate
How fast the outbound traffic leaves the monitored object.
≥ 0
Byte/s
1000 (SI)
1 minute
m9_abnormal_servers
Unhealthy Servers
The number of unhealthy backend servers associated with the monitored object.
≥ 0
Count
N/A
1 minute
ma_normal_servers
Healthy Servers
The number of healthy backend servers associated with the monitored object.
≥ 0
Count
N/A
1 minute
m22_in_bandwidth
Inbound Bandwidth
The bandwidth used for accessing the monitored object from external networks.
≥ 0
bit/s
1000 (SI)
1 minute
m23_out_bandwidth
Outbound Bandwidth
The bandwidth used by the monitored object to access external networks.
≥ 0
bit/s
1000 (SI)
1 minute
m1e_server_rps
Reset Packets from Backend Servers
The number of reset packets sent by backend servers to clients per second. These reset packets are generated by the backend servers and then forwarded by the load balancer.
Supported protocols: TCP
≥ 0
Count/s
N/A
1 minute
m21_client_rps
Reset Packets from Clients
The number of reset packets sent by clients to backend servers per second. These reset packets are generated by clients and then forwarded by the load balancer.
≥ 0
Count/s
N/A
1 minute
m1f_lvs_rps
Reset Packets from Load Balancer
The number of reset packets generated by the load balancer per second.
≥ 0
Count/s
N/A
1 minute
mb_l7_qps
Layer 7 Query Rate
The number of queries the monitored object receives per second at Layer 7.
Supported protocols: HTTP/HTTPS
≥ 0
Count/s
N/A
1 minute
mc_l7_http_2xx
2xx Status Codes (Total)
The number of 2xx status codes returned by the monitored object and backend servers per second at Layer 7.
≥ 0
Count/s
N/A
1 minute
md_l7_http_3xx
3xx Status Codes (Total)
The number of 3xx status codes returned by the monitored object and backend servers per second at Layer 7.
≥ 0
Count/s
N/A
1 minute
me_l7_http_4xx
4xx Status Codes (Total)
The number of 4xx status codes returned by the monitored object and backend servers per second at Layer 7.
≥ 0
Count/s
N/A
1 minute
mf_l7_http_5xx
5xx Status Codes (Total)
The number of 5xx status codes returned by the monitored object and backend servers per second at Layer 7.
≥ 0
Count/s
N/A
1 minute
m10_l7_http_other_status
Other Status Codes (Total)
The number of other status codes returned by the monitored object and backend servers per second at Layer 7.
Excluded status codes: 2xx, 3xx, 404 Not Found, 499 Client Closed Request, and 502 Bad Gateway
≥ 0
Count/s
N/A
1 minute
m11_l7_http_404
404 Not Found (Total)
The number of 404 Not Found status codes returned by the monitored object and backend servers per second at Layer 7.
≥ 0
Count/s
N/A
1 minute
m12_l7_http_499
499 Client Closed Request (Total)
The number of 499 Client Closed Request status codes returned by the monitored object and backend servers per second at Layer 7.
≥ 0
Count/s
N/A
1 minute
m13_l7_http_502
502 Bad Gateway (Total)
The number of 502 Bad Gateway status codes returned by the monitored object and backend servers per second at Layer 7.
≥ 0
Count/s
N/A
1 minute
m14_l7_rt
Average Layer 7 Response Time
Average response time of the monitored object at Layer 7.
The response time starts when the monitored object receives requests from the clients and ends when it returns all responses to the clients.
The average response time it takes to establish a WebSocket connection may be very long. This metric cannot be used as a reference.
≥ 0
ms
1000 (SI)
1 minute
m15_l7_upstream_4xx
4xx Status Codes (Backend Servers)
The number of 4xx status codes returned by the backend servers per second at Layer 7.
≥ 0
Count/s
N/A
1 minute
m16_l7_upstream_5xx
5xx Status Codes (Backend Servers)
The number of 5xx status codes returned by the backend servers per second at Layer 7.
≥ 0
Count/s
N/A
1 minute
m18_l7_upstream_2xx
2xx Status Codes (Backend Servers)
The number of 2xx status codes returned by the backend servers per second at Layer 7.
Supported protocols: HTTP/HTTPS/QUIC
≥ 0
Count/s
N/A
1 minute
m19_l7_upstream_3xx
3xx Status Codes (Backend Servers)
The number of 3xx status codes returned by the backend servers per second at Layer 7.
≥ 0
Count/s
N/A
1 minute
m17_l7_upstream_rt
Average Server Response Time
Average response time of backend servers associated with the monitored object at Layer 7.
The response time starts when the monitored object routes the requests to the backend server and ends when the monitored object receives a response from the backend server.
≥ 0
ms
1000 (SI)
1 minute
m1a_l7_upstream_rt_max
Maximum Server Response Time
Maximum response time of the backend server associated with the monitored object at Layer 7.
≥ 0
ms
1000 (SI)
1 minute
m1b_l7_upstream_rt_min
Minimum Server Response Time
Minimum response time of the backend server associated with the monitored object at Layer 7.
≥ 0
ms
1000 (SI)
1 minute
m1c_l7_rt_max
Maximum Layer 7 Response Time
Maximum response time of the monitored object at Layer 7.
≥ 0
ms
1000 (SI)
1 minute
m1d_l7_rt_min
Minimum Layer 7 Response Time
Minimum response time of the monitored object at Layer 7.
≥ 0
ms
1000 (SI)
1 minute
m25_l7_resp_Bps
Layer 7 Response Bandwidth
The bandwidth used by the backend servers associated with the monitored object to return responses to clients.
When HTTP/2 is enabled for a listener, this metric cannot be used as a reference.
≥ 0
bit/s
1000 (SI)
1 minute
m24_l7_req_Bps
Layer 7 Request Bandwidth
The bandwidth used by the backend servers associated with the monitored object to receive requests from clients.
≥ 0
bit/s
1000 (SI)
1 minute
Listener Metrics
Table 2 Metrics supported by each listener
Metric ID
Name
Value Range
Unit
Conversion Rule
Monitoring Interval
(Raw Data)
m1_cps
Unit: Count
≥ 0
Count
N/A
Shared load balancer - listener
1 minute
m2_act_conn
Active Connections
netstat -an
Unit: Count
≥ 0
Count
N/A
1 minute
m3_inact_conn
netstat -an
Unit: Count
≥ 0
Count
N/A
1 minute
m4_ncps
New Connections
≥ 0
Count/s
N/A
1 minute
m5_in_pps
Incoming Packets
≥ 0
Count/s
N/A
1 minute
m6_out_pps
Outgoing Packets
≥ 0
Count/s
N/A
1 minute
m7_in_Bps
≥ 0
Byte/s
1000 (SI)
1 minute
m8_out_Bps
≥ 0
Byte/s
1000 (SI)
1 minute
m22_in_bandwidth
Inbound Bandwidth
≥ 0
bit/s
1000 (SI)
1 minute
m23_out_bandwidth
Outbound Bandwidth
≥ 0
bit/s
1000 (SI)
1 minute
m1e_server_rps
≥ 0
Count/s
N/A
1 minute
m21_client_rps
≥ 0
Count/s
N/A
1 minute
m1f_lvs_rps
≥ 0
Count/s
N/A
1 minute
mb_l7_qps
Layer 7 Query Rate
≥ 0
Count/s
N/A
1 minute
mc_l7_http_2xx
≥ 0
Count/s
N/A
1 minute
md_l7_http_3xx
≥ 0
Count/s
N/A
1 minute
me_l7_http_4xx
≥ 0
Count/s
N/A
1 minute
mf_l7_http_5xx
≥ 0
Count/s
N/A
1 minute
≥ 0
Count/s
N/A
1 minute
m11_l7_http_404
≥ 0
Count/s
N/A
1 minute
m12_l7_http_499
≥ 0
Count/s
N/A
1 minute
m13_l7_http_502
≥ 0
Count/s
N/A
1 minute
m14_l7_rt
≥ 0
ms
1000 (SI)
1 minute
m15_l7_upstream_4xx
≥ 0
Count/s
N/A
1 minute
m16_l7_upstream_5xx
≥ 0
Count/s
N/A
1 minute
m18_l7_upstream_2xx
≥ 0
Count/s
N/A
1 minute
m19_l7_upstream_3xx
≥ 0
Count/s
N/A
1 minute
m17_l7_upstream_rt
≥ 0
ms
1000 (SI)
1 minute
≥ 0
ms
1000 (SI)
1 minute
≥ 0
ms
1000 (SI)
1 minute
m1c_l7_rt_max
≥ 0
ms
1000 (SI)
1 minute
m1d_l7_rt_min
≥ 0
ms
1000 (SI)
1 minute
m25_l7_resp_Bps
≥ 0
bit/s
1000 (SI)
1 minute
m24_l7_req_Bps
≥ 0
bit/s
1000 (SI)
1 minute
Dimensions
Key
Value
lbaas_instance_id
ID of a shared load balancer
lbaas_listener_id
ID of a listener added to a shared load balancer
