Tag
If you have a large number of cloud resources, you can add different tags to the resources to quickly identify them and use these tags to easily manage your resources.
Adding a Tag to a Load Balancer
You can add a tag to a load balancer in the following methods:
- Add a tag when you create a load balancer.
     For details, see Creating a Shared Load Balancer.
- Add a tag to an existing load balancer.
- In the upper left corner of the page, click  and select the desired region and project. and select the desired region and project.
- Click  in the upper left corner to display Service List and choose Networking > Elastic Load Balance. in the upper left corner to display Service List and choose Networking > Elastic Load Balance.
- On the Load Balancers page, locate the load balancer and click its name.
- Under Tags, click Add Tag.
- In the Add Tag dialog box, enter a tag key and value and click OK.
         - A maximum of 20 tags can be added to a load balancer.
- Each tag is a key-value pair, and the tag key is unique.
Adding a Tag to a Listener
To add a tag to an existing listener, perform the following steps:
- Click Listeners, locate the listener, and click its name.
       - A maximum of 20 tags can be added to a listener.
Modifying a Tag of a Load Balancer
- Click Tags, select the tag to be edited, and click Edit in the Operation column. In the Edit Tag dialog box, enter a tag value.
       The tag key cannot be changed.
The operations for modifying a listener tag are not detailed here. Refer to the operations of modifying a load balancer tag.
Deleting a Tag from a Load Balancer
- Click Tags, select the tag to be deleted, and click Delete in the Operation column.
The operations for deleting a listener tag are not detailed here. Refer to the operations of deleting a load balancer tag.
