Enabling Access Logging for Your Load Balancer
When you use HTTP/HTTPS/QUIC/TLS listeners of a load balancer to route requests, if there is an unhealthy backend server, it is challenging to quickly locate the root cause by checking the logs of this backend server.
Log Tank Service (LTS) can log Layer 7 requests, of a load balancer including the time when the request was sent, client IP address, request path, server response, and more. If there are service faults or exceptions caused by unhealthy backend servers, you can view logs of requests to load balancers and analyze response status codes to quickly locate unhealthy backend servers.
Operations data, such as access logs, of ELB is on the LTS console. Do not transmit private or sensitive data through fields in access logs. Encrypt your sensitive data if necessary.
What Is ELB Access Logging?
ELB receives and distributes client access requests. It logs the details of Layer 7 requests. With LTS, you can quickly analyze service requests and locate faults.
The following information is logged:
- Time information: Fields such as msec and time_iso8601 record the time when requests were sent. They are used for analyzing time sequence and locating faults.
- Basic client request information: Fields such as remote_addr:remote_port, request_method scheme://host request_uri server_protocol, and http_user_agent record basic request information, which is used for user analysis and security audit.
- Request response and performance metrics: Fields such as status, bytes_sent, and request_time record response status and processing time, which are used for locating request status and monitoring performance.
- Load balancer information: Fields such as lb_name, listener_id, pool_name, and eip_address:eip_port record the details of load balancers that are used to route requests. They are used to identify the resource configuration and improve O&M efficiency.
- Backend server information: Fields such as upstream_status, upstream_connect_time, and upstream_addr_priv record the information returned by backend servers and their configurations. They are used to identify the health status and performance of the backend servers.
- HTTPS information: Fields such as ssl_protocol, sni_domain_name, and certificate_id record the HTTPS information for troubleshooting HTTPS requests.
- Other information: Fields such as access_log_topic_id, log_ver, and tenant_id record the system and log IDs for log management.
Billing
After ELB is interconnected with LTS, LTS charges you based on the log read/write traffic, log storage volume, and log transfer traffic. For details, see LTS Billing Items.
- Access logging can be configured only for load balancers with HTTP, QUIC, TLS, or HTTPS listeners.
- The access logs do not contain requests whose return code is 400 Bad Request. This is because such requests do not comply with HTTP specification and cannot be processed properly.
Preparations
- Create a load balancer that supports HTTP, QUIC, TLS, and HTTPS. For details, see Creating a Dedicated Load Balancer.
- Enable LTS. For details, see Accessing LTS.
- Create a backend server group, add backend servers to the group, and deploy services on the backend servers. For details, see Creating a Backend Server Group.
- Add an HTTP, QUIC, TLS, or HTTPS listener to the load balancer.
Configuring Access Logging
- Go to the load balancer list page.
- On the Load Balancers page, locate the load balancer and click its name.
- Under Access Logs, click Configure Access Logging.
- Enable access logging and select the log group and log stream you have created.
If there are no log groups and log streams, you can create such resources on the ELB console.
- Click OK.
Viewing Access Logs
You can view details about access logs on the:
- ELB console: Go to the Access Logs tab of the target load balancer to view access logs.
- (Recommended) LTS console: Locate the target log group and click its name. On the displayed page, locate the target log stream and click Real-Time Logs tab.
The log format is as follows and cannot be modified:
$msec $access_log_topic_id [$time_iso8601] $log_ver $remote_addr:$remote_port $status "$request_method $scheme://$host$router_request_uri $server_protocol" $request_length $bytes_sent $body_bytes_sent $request_time "$upstream_status" "$upstream_connect_time" "$upstream_header_time" "$upstream_response_time" "$upstream_addr" "$http_user_agent" "$http_referer" "$http_x_forwarded_for" $lb_name $listener_name $listener_id $pool_name "$member_name" $tenant_id $eip_address:$eip_port "$upstream_addr_priv" $certificate_id $ssl_protocol $ssl_cipher $sni_domain_name $tcpinfo_rtt $self_defined_header $request_header_length $actions_executed $error_reason "$pool_usr_name"
The following is a log example:
1644819836.370 eb11c5a9-93a7-4c48-80fc-03f61f638595 [2024-02-14T14:23:56+08:00] elb_01 192.168.1.1:888 200 "POST https://www.test.com/example/ HTTP/1.1" 1411 251 3 0.011 "200" "0.000" "0.011" "0.011" "192.168.1.2:8080" "okhttp/3.13.1" "-" "-" loadbalancer_295a7eee-9999-46ed-9fad-32a62ff0a687 listener_20679192-8888-4e62-a814-a2f870f62148 3333fd44fe3b42cbaa1dc2c641994d90 pool_89547549-6666-446e-9dbc-e3a551034c46 "-" f2bc165ad9b4483a9b17762da851bbbb 121.64.212.1:443 "10.1.1.2:8080" - TLSv1.2 ECDHE-RSA-AES256-GCM-SHA384 www.test.com 56704 "-" 129 waf - "My backend server group"
Log analysis:
At 14:23:56 GMT+08:00 on Feb 14, 2024, the load balancer received an HTTP/1.1 POST request from a client whose IP address and port number are 192.168.1.1 and 888, then routed the request to a backend server whose IP address and port number are 100.64.0.129 and 8080, and finally returned 200 OK to the client after receiving the status code from the backend server.
Log analysis result:
The backend server responds to the request normally.
Table 1 describes the fields in the log.
Parameter |
Description |
Value Description |
Example Value |
msec |
Time when the log is written, in seconds with a milliseconds resolution. |
Floating-point data |
1644819836.370 |
access_log_topic_id |
Log stream ID. |
uuid |
eb11c5a9-93a7-4c48-80fc-03f61f638595 |
time_iso8601 |
Local time in the ISO 8601 standard format. |
N/A |
[2024-02-14T14:23:56+08:00] |
log_ver |
Log format version. |
Fixed value: elb_01 |
elb_01 |
remote_addr: remote_port |
IP address and port number of the client. |
Records the IP address and port of the client. |
192.168.1.1:888 |
status |
HTTP status code. |
Records the request status code. |
200 |
request_method scheme://host request_uri server_protocol |
Request method Protocol://Host name: Request URI Request protocol |
"POST https://www.test.com/example/ HTTP/1.1" |
request_length |
Length of the request received from the client, including the header and body. |
Integer |
1411 |
bytes_sent |
Number of bytes sent to the client. |
Integer |
251 |
body_bytes_sent |
Number of bytes sent to the client (excluding the response header). |
Integer |
3 |
request_time |
Request processing time in seconds from the time when the load balancer receives the first request packet from the client to the time when the load balancer sends the response packet. |
0.011 |
upstream_status |
Response status code returned by the backend server.
HTTP status code returned by the backend server to the load balancer |
"200" |
upstream_connect_time |
Time taken to establish a connection with the server, in seconds, with a milliseconds resolution.
"0.000" |
upstream_header_time |
Time taken to receive the response header from the server, in seconds, with a milliseconds resolution.
"0.011" |
upstream_response_time |
Time taken to receive the response from the server, in seconds, with a milliseconds resolution.
"0.011" |
upstream_addr |
IP address and port number of the backend server. There may be multiple values separated by commas and spaces, and each value is in the format of {IP address}:{Port number} or -. |
IP address and port number |
"192.168.1.2:8080" |
http_user_agent |
http_user_agent in the request header received by the load balancer, indicating the system model and browser information of the client. |
Records the browser-related information. |
"okhttp/3.13.1" |
http_referer |
http_referer in the request header received by the load balancer, indicating the page link of the request. |
Request for a page link |
http_x_forwarded_for |
http_x_forwarded_for in the request header received by the load balancer, indicating the IP address of the proxy server that the request passes through. |
IP address |
lb_name |
Load balancer name in the format of loadbalancer_load balancer ID |
String |
loadbalancer_295a7eee-9999-46ed-9fad-32a62ff0a687 |
listener_name |
Listener name in the format of listener_listener ID. |
String |
listener_20679192-8888-4e62-a814-a2f870f62148 |
listener_id |
ID of the listener added to the load balancer. |
String |
3333fd44fe3b42cbaa1dc2c641994d90 |
pool_name |
Backend server group name in the format of pool_backend server group ID or pool_backend server group ID*load balancer ID. |
String |
pool_89547549-6666-446e-9dbc-e3a551034c46 |
member_name |
Backend server name in the format of member_server ID. This field is not supported yet. There may be multiple values separated by commas and spaces, and each value is a member ID (member_id) or -. |
String |
tenant_id |
Tenant ID. |
String |
f2bc165ad9b4483a9b17762da851bbbb |
eip_address:eip_port |
EIP of the load balancer and frontend port that were set when the listener was added. |
121.64.212.1:443 |
upstream_addr_priv |
"-" (Dedicated load balancers) |
certificate_id |
HTTPS listener: Certificate ID used for establishing an SSL connection. This field is not supported yet. |
String |
N/A |
ssl_protocol |
HTTPS listener: Protocol used for establishing an SSL connection. For a non-HTTPS listener, a hyphen (-) is displayed as a null value for this field. |
String |
TLSv1.2 |
ssl_cipher |
HTTPS listener: Cipher suite used for establishing an SSL connection. For a non-HTTPS listener, a hyphen (-) is displayed as a null value for this field. |
String |
ECDHE-RSA-AES256-GCM-SHA384 |
sni_domain_name |
HTTPS listener: SNI domain name provided by the client during SSL handshakes. For a non-HTTPS listener, a hyphen (-) is displayed as a null value for this field. |
String |
www.test.com |
tcpinfo_rtt |
TCP Round Trip Time (RTT) between the load balancer and client in microseconds. |
Integer |
56704 |
self_defined_header |
This field is reserved. The default value is -. |
String |
request_header_length |
The size of the header in the client request. |
Integer |
129 |
actions_executed |
The WAF execution result. |
String
waf |
error_reason |
Reason why requesting WAF fails. |
String
N/A |
Locating an Unhealthy Backend Server
The following is a log that records an exception:
1554944564.344 - [2024-04-11T09:02:44+08:00] elb 10.133.251.171:51527 500 "GET http://10.154.73.58/lrange/guestbook HTTP/1.1" 411 3726 3545 19.028 "500" "0.009" "19.028" "19.028" "172.17.0.82:3000" "Mozilla/5.0 (Windows NT 6.1; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/73.0.3683.103 Safari/537.36" "http://10.154.73.58:5971/" "-" loadbalancer_ed0f790b-e194-4657-9f97-53426227099e listener_b21dd0a9-690a-4945-950e-b134095c6bd9 6b6aaf84d72b40fcb2d2b9b28f6a0b83
Log analysis
At 09:02:44 GMT+08:00 of April 11, 2024, the load balancer received a GET/HTTP/1.1 request from the client whose IP address and port number are 10.133.251.171 and 51527 respectively and then routed the request to a backend server that uses 172.17.0.82 and port 3000 to receive requests. The load balancer then received 500 Internal Server Error from the backend server and returned the status code to the client.
Analysis results
The backend server (private IP address: 172.17.0.82; port: 3000) was unhealthy and failed to respond to the request.
Helpful Links
- Best practices: Querying Client IP Addresses in ELB Access Logs
- If you want to perform secondary analysis on logs, you can transfer logs to other cloud services.
- If you want to manage ELB logs in a unified manner, see the following documentation:
- APIs: Creating a Log and Viewing the Details of a Log
