Updated on 2026-09-18 GMT+08:00
Advanced Forwarding
When you use ELB to distribute Layer 7 requests, you may need different forwarding policies to route different client requests. In this case, you can configure advanced forwarding policies to route requests to the right server based on the characteristics of client requests.
Overview
You can configure advanced forwarding policies to forward requests to different backend server groups based on a wide range of forwarding rules and actions, facilitating flexible traffic distribution and proper resource allocation.
The following describes how an advanced forwarding policy works.
  1. A client sends a request to a load balancer.
  2. The load balancer matches each client request based on the forwarding policies you configure. Each forwarding policy can have multiple forwarding rules. If multiple matches are found, the load balancer routes the request based on the forwarding policy priorities.
  3. The load balancer routes the request to the backend server based on the action of the matched forwarding policy.
  4. The load balancer sends a response to the client.
Figure 1 How advanced forwarding works
Table 1 Rules and actions supported by an advanced forwarding policy
Forwarding Policy Settings
Forwarding rule
The following forwarding rules are supported: domain name, path, HTTP request method, HTTP header, query string, cookie, and CIDR block.
For details, see Forwarding Rule.
Forwarding action
The following actions are supported: forward to a backend server group, redirect to another listener, redirect to another URL, rewrite, write header, remove header, limit request, and return a specific response body.
  • If Action is set to Forward to a backend server group, you can also select from one of the following additional forwarding actions: rewrite, write header, remove header, and limit request.
  • If Action is set to Return a specific response body, you can also select the additional action Limit request.
For details, see Action Types.
Cookie-based forwarding rules can be configured. Additional actions rewrite, write header, remove header, and limit request are only available in certain regions. You can check which regions support them on the console. If you want to use this feature, submit a service ticket.
How Requests Are Matched
  • Matching policies: Each client request is matched against forwarding policies. Once a match is found, the request is forwarded based on this forwarding policy. If multiple matches are found, the request is forwarded based on the forwarding policy priorities. A smaller forwarding policy number indicates a higher priority and is matched first.
    • If multiple conditions are configured for a forwarding policy, the request can match this forwarding policy only when all the conditions are met.
    • If the request matches any forwarding policy of the listener, it is forwarded based on this forwarding policy.
    • If the request does not match any forwarding policy, it is forwarded based on the default forwarding policy.
  • Forwarding policy priority: After advanced forwarding is enabled, each forwarding policy has a priority value based on its creation time. If a client request matches the forwarding rules of multiple forwarding policies, the policy priority determines the matching and forwarding order.
    • The smaller the forwarding policy priority value, the higher the priority and the earlier the policy is evaluated.
    • When an advanced forwarding policy is added, its priority value is automatically incremented by 1 and inserted above the default forwarding policy.
    • You can change the priority of a forwarding policy by modifying its priority value or by using the Sort function to drag and reorder the policy module.
  • Default forwarding policy: After you add a Layer 7 listener to a load balancer, a default forwarding policy is generated. The load balancer then uses this policy to forward requests to the backend server group you specified when adding the listener.
    • If a client request does not match any forwarding policy, it is forwarded according to the default forwarding policy.
    • The default forwarding policy has the lowest priority, which cannot be sorted. You can modify the default backend server group, but cannot delete the default forwarding policy.
Forwarding Rule
Advanced forwarding policies support the following types of forwarding rules: domain name, path, HTTP request method, HTTP header, query string, cookie, and CIDR block.
Table 2 Forwarding rules
Forwarding Rule
Domain name
  • Description
    Route requests based on the domain name. You can configure multiple domain names with each consisting of at least two labels separated by periods (.). Each domain name can contain a maximum of 63 characters per label and a maximum total length of 100 characters.
  • Matching rules
    • Exact match and wildcard match: The domain name can contain only letters, digits, and special characters: .-?=~_+\^*!$&|()[]. Asterisks (*) and question marks (?) can be used as wildcards. The domain name cannot start or end with a period (.) or contain two consecutive periods (..).
    • Regular expression match: The domain name can contain only letters, digits, and special characters: .-?=~_+\^*!$&|()[].
Example
Request URL: https://www.example.com/login.php?locale=en-us=#videos
Domain name in the forwarding rule: www.example.com
Path
  • Description
    Route requests based on paths. You can configure multiple paths in a forwarding policy. Each path contains 1 to 128 characters, including letters, digits, and special characters: _~';@^-%#$.*+?,=!:|\/()[]{}.
  • Matching rules
    • Exact match: The request path is the same as the specified path and must start with a slash (/).
    • Prefix match: The request path starts with the specified path string and must start with a slash (/).
    • Regular expression match: The request path is matched against the specified path using a regular expression.
For more information about path matching rules, see Path Matching.
Example path:
Request URL: https://www.example.com/login.php?locale=en-us#videos
Path in the forwarding rule: /login.php
Query string
Route requests based on the query string.
A query string consists of a key and one or more values. You need to set the key and values separately.
  • The key can contain only letters, digits, and special characters: !$'()*+,./:;=?@^-_'
  • Multiple values can be configured for a key. The value can contain letters, digits, and special characters: !$'()*+,./:;=?@^-_'. Asterisks (*) and question marks (?) can be used as wildcard characters.
Example
A query string needs to be configured for the forwarding rule:
Key: locale
Value: en-us
HTTP request method
Route requests based on the HTTP method.
  • You can configure multiple request methods in a forwarding policy.
  • The following methods are available: GET, POST, PUT, DELETE, PATCH, HEAD, and OPTIONS.
Example
GET
HTTP header
Route requests based on the HTTP header.
An HTTP header consists of a key and one or more values. You need to configure the key and values separately.
  • The key can contain only letters, digits, underscores (_), and hyphens (-).
    The first letter of HTTP request headers User-agent and Connection must be capitalized.
  • Multiple values can be configured for a key. The value can contain letters, digits, and special characters: !#$%&'()*+,.\/:;<=>?@[]^-_'{|}~. Asterisks (*) and question marks (?) can be used as wildcard characters.
Example
Key: Accept-Language
Value: en-us
CIDR block
Route requests based on the source IP addresses from where requests originate.
Example
192.168.1.0/24 or 2020:50::44/127
Cookie
Route requests based on the cookie.
A cookie consists of a key and a value. You need to configure the key and value separately.
  • A key can contain 1 to 100 characters and cannot start or end with a space.
  • A key can have one value, which can contain 1 to 100 characters.
You can enter multiple key-value pairs. The key-value pairs can contain letters, digits, and special characters: !%'"()*+,./:=?@^-_`~
Example:
Key: cookie_name
Value: cookie_value
Action Types
Advanced forwarding policies support the following actions: forward to a backend server group, redirect to another listener, redirect to another URL, and return a specific response body.
If you set Action to Forward to backend server group or Return a specific response body, you can add additional actions. ELB first matches traffic based on additional actions and then forwards requests to the specified backend server group or returns a specific response body. Among all the additional actions, Limit request has the highest priority.
The following additional actions are supported:
  • Forward to backend server group: rewrite, write header, remove header, and limit request
  • Return a specific response body: limit request
Table 3 Actions of an advanced forwarding policy
Action
Requests are forwarded to the specified backend server group.
If Action is set to Forward to a backend server group, you can also select from one of the following additional actions: rewrite, write header, remove header, and limit request.
For details, see Table 4.
Redirect to another listener
Requests are redirected to another listener, which then routes the requests to its associated backend server group.
After the redirection is added, the forwarding policies with lower priorities than the current policy will not be applied.
For example, if you configure a redirect for an HTTP listener, HTTP access to a web page will be redirected to the HTTPS listener you select and handled by the backend servers associated with the HTTPS listener. As a result, the clients access the web page over HTTPS.
Redirect to another URL
Requests are redirected to the configured URL.
When clients access website A, the load balancer returns 302 or any other 3xx status code and automatically redirects the clients to website B. You can customize the redirection URL that will be returned to the clients.
Configure at least one of the following components:
  • Protocol: ${protocol}, HTTP, or HTTPS ${protocol}: retains the protocol of the request.
  • Domain Name: A domain name consists of at least two labels separated by periods (.). Each label can contain only letters, digits, hyphens (-), and periods (.), must start with a letter or digit and cannot end with a hyphen (-). ${host}: retains the domain name of the request.
  • Port: ranges from 1 to 65535. ${port}: retains the port number of the request.
  • Path: A path can contain letters, digits, and special characters: _~';@^-%#&$.*+?,=!:|\/()[]{} and must start with a slash (/). ${path}: retains the path of the request.
    If you select regular expression match, the request path in Redirect to another URL and Rewrite will be overwritten by the variables that match the regular expressions. For details, see Path Matching Based on Regular Expressions.
  • Query String: A query string can contain only letters, digits, and special characters: !$'()*+,./:;=?@&^-_',&. Ampersands (&) can only be used as separators.
  • HTTP Status Code: 301, 302, 303, 307, or 308
Example
URL for redirection: http://www.example1.com/index.html?locale=en-us#videos
Protocol: HTTP
Domain name: www.example1.com
Port: 8081
Path: /index.html
Query String: locale=en-us
Load balancers return a fixed response to the clients.
You can customize the status code and response body that load balancers directly return to the clients without the need to route the requests to backend servers.
Configure the following parameters:
  • HTTP Status Code: By default, 2xx, 4xx, and 5xx status codes are supported.
  • Content-Type: text/plain, text/css, text/html, application/javascript, or application/json
  • Message Body: This parameter is optional. The value can contain 0 to 1,024 characters.
Example
text/plain
Sorry, the language is not supported.
text/css
<head><style type="text/css">div {background-color:red}#div {font-size:15px;color:red}</style></head>
text/html
<form action="/" method="post" enctype="multipart/form-data"><input type="text" name="description" value="some text"><input type="file" name="myFile"><button type="submit">Submit</button></form>
To display languages other than English, you are advised to add <meta charset="utf-8"> to the message body. If you do not do this, the languages may appear as garbled characters.
String.prototype.trim = function() {var reExtraSpace = /^\s*(.*?)\s+$/;return this.replace(reExtraSpace, "$1")}
application/json
{ "publicip": { "type": "5_bgp","ip_version": 4},"bandwidth": {"name": "bandwidth123","size": 10,"share_type": "PER"}}
Ensure that the response body does not contain carriage return characters. Otherwise, it cannot be saved.
Table 4 Actions (optional)
Action
Rewrite
Rewrites the request URL before forwarding requests to the specified backend server group.
  • Domain Name: A domain name consists of at least two labels separated by periods (.). Each label can contain only letters, digits, hyphens (-), and periods (.), must start with a letter or digit, and cannot end with a hyphen (-). If you use special characters {}, only the ${host} format is supported, which indicates the domain name in the request is retained.
  • Path: A path can contain letters, digits, and special characters: _~';@^-%#&$.*+?,=!:|\/()[]{} and must start with a slash (/). If you use special characters {}, only the ${path} format is supported, which indicates the path in the request is retained.
    If you select regular expression match, the request path will be overwritten by the variables that match the regular expressions. For details, see Path Matching Based on Regular Expressions.
  • Query String: A query string can contain only letters, digits, and the following special characters: !$'()*+,./:;=?@&^-_', and ampersands (&) can only be used as separators.
The domain name, path, and query string cannot be left blank or made default.
Write header
In the requests forwarded by a load balancer, the header keys of information such as client ports, client IP addresses, and load balancer listener ports are fixed. If your service needs the information but cannot directly identify the original header keys in the request, you can write headers into the request to convert the information. You can set the key of a new header to a name that can be directly identified by your service and use the value of a header in the original request as the value of the new header.
If a request matches the forwarding condition, the load balancer will write the configured headers into the request before forwarding it to the specified backend server group. The original headers in the request remain unchanged. By default, you can configure five headers.
A header is a key-value pair, and you need to set the key and value separately.
  • Key: A key contains 1 to 40 characters and can contain only letters, digits, underscores (_), and hyphens (-).
  • Value: You can define values, or use system-defined or reference values.
    • Manually-defined value: You can define values.
      Each value cannot start or end with a space and can contain 1 to 128 characters, including letters, digits, and special characters: !#$%&'"()*+,.\\/:;<=>?@[]^-_`{|}~.
    • System-defined value: You can use the system-defined values of the below options contained in the original request.
      Client port, client IP address, request protocol, load balancer instance ID, listener port, load balancer EIP, and load balancer private IP
    • Reference value: You can use the value of a header in the original request as the value of the new header.
      The value can contain only letters, digits, underscores (_), and hyphens (-).
For details about how to write a header, see Table 5.
Remove header
Removes the configured headers from the request before forwarding it to the specified backend server group.
You can specify the value of the header you want to remove from the request that matches the forwarding rule. The headers that match the ones you have configured will be removed from the requests. By default, you can configure five headers.
Limit request
Limits the maximum number of queries per second if Forward to a backend server group or Return a specific response body is selected as the action.
You need to configure the following parameters:
  • QPS (Total): Specifies the maximum number of queries per second (QPS). The value ranges from 1 to 100000. If the number of requests reaches the specified value, new requests will be discarded and 503 Service Unavailable will be returned to the client.
  • QPS (Client IP Address): Specifies the maximum number of QPS from a source IP address. The value ranges from 1 to 100000. If both QPS (Total) and QPS (Client IP Address) are configured, the latter value must be smaller than the former. If the number of requests reaches the specified value, new requests will be discarded and 503 Service Unavailable will be returned to the client.
    QPS (Client IP Address) is not available for QUIC listeners.
Your service may require port numbers, which can be obtained through the Custom-Define-Forwarded-Port header key. However, load balancers use ELB-PORT as the header key by default, so your service will not be able to identify the port numbers. To fix this, you can add a header to a request to pass the listener port numbers to the backend service. The below table describes three ways to achieve this.
Table 5 An example for writing a header
Request Header
Header Key
Header Value
Written Request Header
User-Agent: curl/8.5.0
ELB-PORT:9000
User-defined value
9000
ELB-PORT:9000
Custom-Define-Forwarded-Port:9000
Listener port
The key of the header for the listener port is ELB-PORT.
ELB-PORT:9000
Reference value
elb-port
ELB-PORT:9000
The value of the following headers (case-insensitive) cannot be modified:
connection, upgrade, content-length, transfer-encoding, keep-alive, te, host, cookie, remoteip, authority, x-forwarded-host, x-forwarded-for, x-forwarded-for-port, x-forwarded-tls-certificate-id, x-forwarded-tls-protocol, x-forwarded-tls-cipher, x-forwarded-elb-ip, x-forwarded-port, x-forwarded-elb-id, x-forwarded-elb-vip, x-real-ip, x-forwarded-proto, x-nuwa-trace-ne-in, and x-nuwa-trace-ne-out
Path Matching
Table 6 shows how the five paths configured in the forwarding policies match those in the requests.
Table 6 Path matching examples
Request Path
Forwarding Policy
Specified Path
Matching Mode
Forwarding Policy Priority
Destination Backend Server Group
/elb/abc.html
Forwarding policy 01
/elb/abc.html
Prefix match
Backend server group 01
Forwarding policy 02
/elb
Prefix match
2
Backend server group 02
/exa/index.html
Forwarding policy 03
/exa[^\s]*
3
Backend server group 03
Forwarding policy 04
/exa/index.html
4
Backend server group 04
/mpl/index.html
Forwarding policy 05
/mpl/index.html
Exact match
5
Backend server group 05
URLs are matched as follows:
  • When the request path is /elb/abc.html, it matches both forwarding policy 01 and forwarding policy 02. However, the priority of forwarding policy 01 is higher than that of forwarding policy 02. Forwarding policy 01 is used, and requests are forwarded to backend server group 01.
  • When the request path is /exa/index.html, it matches both forwarding policy 03 and forwarding policy 04. However, the priority of forwarding policy 03 is higher than that of forwarding policy 04. Forwarding policy 03 is used, and requests are forwarded to backend server group 03.
  • If the request path is /mpl/index.html, it matches forwarding policy 05 exactly, and requests are forwarded to backend server group 05.
A path can contain letters, digits, and special characters: _~';@^-%#&$.*+?,=!:|\/()[]{} and must start with a slash (/). ${path} retains the path of the request.
How Request Paths Are Overwritten
  1. Path matching: The client sends a request, and the request matches a regular expression in the forwarding rule. You can specify one or more regular expressions as the match conditions and set multiple capture groups represented by parentheses ( ) for one regular expression.
  2. Extraction and replacement: extracts the content from the capture groups.
  3. Destination path: writes them to $1, $2, all the way to $9 configured for the path.
Example
When a client requests to access /test/ELB/elb/index, which matches the regular expression /test/(.*)/(.*)/index, $1 will be replaced by ELB and $2 by elb, and then the request will be redirected to /ELB/elb.
Table 7 URL matching based on regular expressions
Matching Step
Forwarding rule: path
  • Matching condition: /test/(.*)/(.*)/index
  • Request path: /test/ELB/elb/index
Action: rewrite or redirect to another URL
Path
  • Path: /$1/$2
  • Extracting content
    $1: ELB
    $2: elb
  • Destination path: /ELB/elb
Popular Questions
